🚀 [B]Rugged AI Computer for Harsh Industrial Environments: SINTRONES ABOX-5221(P)(G)-IP66 Series![/B]
    ⚙️ Next-Generation Industrial AI Solution​
    SINTRONES has introduced the ABOX-5221(P)(G)-IP66 Series, a next-generation edge AI computer designed for demanding industrial automation environments. This robust device offers reliable performance even in high-vibration applications, thanks to its IP66 protection rating and discrete GPU acceleration.
    🌡️ Thermal and Mechanical Durability​
    Deploying deep learning networks in mobile or outdoor applications presents challenges such as thermal constraints, mechanical shocks, moisture ingress, and electrical noise. The ABOX-5221(P)(G)-IP66 Series combines multi-gigabit network connectivity and discrete GPU acceleration within an environmentally sealed chassis to overcome these operational limitations.
    🧠 Powerful Processor and Memory Integrity​
    • Equipped with Intel Core Series 2 embedded processors (Bartlett Lake family).
    • Various processor configurations: Core 9 273PTE (Performance cores only), Core 7 251TE (8 Performance + 16 Efficient cores), Core 5 221TE (6 Performance + 8 Efficient cores).
    • Support for ECC (Error Correcting Code) memory to prevent software error memory failures in mission-critical deployments.
    • Hardware-assisted security controls and remote management with integrated Intel vPro technology.
    🛡️ Sealed Enclosure and Passive Liquid Cooling​
    • Extruded aluminum enclosure with IP66 protection rating, resistant to dust and high-pressure water jets.
    • M12 threaded connectors for main DC power, Ethernet, digital input/output (DIO), and serial COM ports prevent mechanical loosening.
    • Operates in an industrial temperature range of -40°C to 70°C.
    • Compliant with EN 50155, EN 45545-2 (R25 hazard level), EN 62368-1, and MIL-STD-810H standards.
    • Easy maintenance with a front-accessible Real-Time Clock (RTC) battery slot.
    • Optional patented passive liquid cooling loop for high-density computing cards, supporting up to 682 AI TOPS with NVIDIA RTX 5000 Ada Generation. This system offers five times more thermal dissipation efficiency than traditional coolers.
    ⚡ High-Bandwidth Networking and Industrial Applications​
    • High-capacity data flow with dual 10GbE network interfaces.
    • Four additional 2.5GbE ports, with optional PoE+ support, provide power and data to industrial cameras and sensors.
    • Peripheral interfaces such as USB 3.2 Gen 2, isolated DIO, and COM ports.
    • A wide range of applications including intelligent transportation systems (ITS), smart agriculture, factory inspection, unmanned ground vehicles (UGV), and unmanned aerial vehicles (UAV).
    🚂 Specifically Designed for Railway and Heavy Vehicle Systems​
    The ABOX-5221(P)(G)-IP66 Series meets IEC 61373 categories for vibration and mechanical shock tolerances, compliant with the EN 50155 railway standard. Furthermore, it adheres to the strict flammability, smoke emission, and toxicity limits for electronic enclosures used in passenger and driver compartments, as per the EN 45545-2 R25 requirement set.
    🚀 Superiority Over Competing Systems​
    The NVIDIA RTX 5000 Ada Generation mobile or MXM module produces 682 AI TOPS (with 8-bit floating-point precision) with 9,728 CUDA cores and 16GB GDDR6 memory. This discrete accelerator offers higher performance compared to integrated systems. While competing industrial platforms often rely on external cooling fans or IP67-rated fan assemblies, SINTRONES' passive liquid cooling solution eliminates mechanical failure points and reduces maintenance requirements in harsh environments.
