✨ Next-Generation 10GigE Imaging System from Basler
Basler has introduced a compact and high-performance 10GigE imaging system designed for data-intensive machine vision applications in industrial automation. This system stands out with stable data transmission, low CPU load, and energy efficiency. Thanks to its integrated hardware and software architecture, system complexity, integration time, and operating costs are significantly reduced.
⚙️ Technical Specifications and Advantages
- Compact Design: ace 2 10GigE cameras, with dimensions of 29x29x61.5 mm, can be easily integrated into confined spaces.
- High Resolution and Speed: Offers resolutions up to 24.4 megapixels and speeds of 232 frames per second thanks to Sony Pregius S sensors.
- RDMA Support: Remote Direct Memory Access (RDMA) protocol minimizes latency between image acquisition and processing. This significantly reduces CPU load and ensures high bandwidth even in multi-camera setups.
- Low Power Consumption: With power consumption below 7 watts, it reduces heat dissipation and operating costs.
- Flexible Connectivity: Provides both data and power transmission over a single cable with RJ45 connectors and Power over Ethernet (PoE) support. The SFP+ interface option also offers a solution for long-distance cabling needs.
- Extensive Ecosystem: Offers a complete solution with compatible lenses, telecentric optics, and special lighting modules.
💡 Application Areas
This system is ideal for industrial applications requiring high bandwidth, such as quality control, robot guidance, logistics, wafer inspection, and semiconductor manufacturing.
🌐 GigE Vision 3.0 Standard
The 10GigE imaging ecosystem is based on the GigE Vision 3.0 standard. This standard uses RoCE (RDMA over Converged Ethernet) technology to transfer image packets directly to application memory. This bypasses the operating system's network stack, significantly reducing CPU usage and enabling continuous multi-camera data streams without packet loss.
📈 Competitive Comparison
Compared to standard 1GE and USB3 Vision architectures, RDMA-enabled 10GigE systems offer ten times more theoretical bandwidth and eliminate the cable length limitations of USB3. Compared to alternatives like Camera Link HS or CoXPress, they reduce total system cost by using standard Ethernet cabling infrastructure and network interface hardware, while maintaining sub-millisecond deterministic latency for industrial automation tasks.
