Advantech Ushers in a New Era in Robot Control
Advantech has introduced the ASR-A503 and AFE-A503 platforms, which integrate AI, vision processing, and robot control into a single architecture. These innovative solutions are powered by the Qualcomm Dragonwing™ IQ-9075M processor and are specifically designed to meet the system requirements of next-generation Autonomous Mobile Robots (AMRs), humanoid robots, and service robots.
High Performance and Efficiency on a Single Chip
While AI performance (TOPS) is often prioritized in edge computing, Advantech's new platforms perfectly balance performance-per-watt, thermal design, and robust I/O. The ASR-A503 SBC offers up to 100 dense TOPS (and 200 sparse TOPS) of performance, providing developers with flexible integration options. It also supports up to 8 camera inputs (GMSL and MIPI-CSI), GbE, CAN FD, digital I/O, and serial interfaces.
Robust Solution for Industrial Applications: AFE-A503
Designed for faster field deployment, the AFE-A503 brings the ASR-A503's architecture into a robust, fully integrated industrial enclosure. With isolated interfaces, wide operating temperature range (-40 to 85°C), and 20 to 36 VDC power input, it eliminates extensive hardware integration efforts.
Ending Hardware Fragmentation in Mobile Robotics
One of the biggest engineering challenges in mobile robotics was hardware fragmentation. Traditionally, building an AMR involved using a separate GPU for AI inference, an x86 processor for path planning, and a separate microcontroller (MCU) for real-time motor control. This multi-chip approach occupied excessive space, required complex cooling, and rapidly depleted battery life.
Integrated Solution with Qualcomm Dragonwing IQ-9075M
The Qualcomm Dragonwing IQ-9075M solves these problems by distributing these workloads onto a single System-on-Chip (SoC). The integrated Neural Processing Unit (NPU) and Image Signal Processor (ISP) handle perception tasks, while the Kryo CPU cores manage the complex mathematical operations of SLAM (Simultaneous Localization and Mapping) and path planning. Dedicated real-time subsystems provide deterministic I/O for motor control. By keeping all this data on a single chip with shared memory, Advantech platforms significantly reduce power consumption and thermal output. This offers a critical advantage for battery-powered humanoid robots and warehouse logistics robots.
