✨ FLUX GmbH Introduces New IND-ROT-G Rotary Encoder for Harsh Conditions! ✨
FLUX GmbH has launched the IND-ROT-G, a new high-precision and durable rotary encoder designed for industrial automation and robotics applications. This compact, frameless inductive encoder sets a new standard in the industry by providing absolute position feedback even in challenging environmental conditions.
🛡️ Maximum Durability with IP67 Protection 🛡️
The IND-ROT-G stands out with its protected structure, boasting an IP67 rating. This ensures reliable performance even in dusty, humid, and heavily contaminated environments. This protection, provided without increasing the physical size of the encoder, offers a significant advantage, especially for applications with space constraints.
🎯 High Resolution, Wide Range of Applications 🎯
- Size Variety: Offers four different outer diameter options, ranging from 55 mm to 96 mm.
- Superior Resolution: With up to 21 bits of resolution, it provides more than two million unique position data points per revolution. This is critical for precise applications such as surgical robots or long-range optical gimbals.
- Durability: Designed for reliable operation against high shock, heavy vibration, and extreme temperature fluctuations.
- Lightweight Design: Its stators weigh only 22 grams, providing protection without adding extra weight to the system.
- Easy Installation: Offers quick and practical installation thanks to its plug-and-play feature, which requires no calibration.
- Broad Compatibility: Supports standard industrial communication interfaces such as BiSS-C, SSI, and incremental A/B/Z.
💡 Advantages of Inductive Technology 💡
Inductive encoders, operating on the principle of electromagnetic induction, are naturally resistant to environmental contaminants such as oil, dust, and moisture. The IND-ROT-G's IP67 rating allows engineers to use this sensor directly in washdown environments or on outdoor robots without the need to design special sealed enclosures.
🚀 Ideal Application Areas 🚀
This new encoder offers an excellent feedback solution for demanding applications with size constraints and high precision requirements, such as unmanned aerial vehicles (UAVs), stabilized camera gimbals, medical robots, and industrial automation equipment.
