☀️ [B]Powerful Display in Outdoor Environments: New Industrial Monitors from Advantech! 🚀[/B]
    ✨ Screens That Defy Harsh Conditions​
    Advantech has introduced the FPM-300S, a new generation of high-brightness, impact-resistant monitors designed for outdoor industrial automation. These monitors have been specifically developed to maintain screen visibility and operational stability even in challenging outdoor and semi-outdoor environments.
    🎯 Wide Range of Applications​
    Targeting sectors such as transportation, energy infrastructure, and smart city systems, these monitors provide reliable data visualization for electric vehicle charging stations, port terminals, and specialized industrial facilities.
    💡 Superior Display Technology​
    • 1800 Nit Brightness: Offers excellent visibility even in direct sunlight.
    • Anti-Glare Coating: Reduces surface reflections.
    • UV Protection: Prevents yellowing and material degradation from prolonged UV exposure.
    • Optical Bonding: Combines the cover glass, touch panel, and LCD into a single sealed layer, reducing internal reflection and preventing moisture ingress and fogging.
    • Auto-Dimming: Dynamically adjusts backlight intensity according to ambient light for optimal visibility.
    🛡️ Environmental Durability​
    • IK08 Impact Resistance: The front surface can withstand impacts up to 5 joules.
    • IP66 Front Panel Protection: Protects internal electronics against heavy dust ingress and high-pressure water jets.
    • Wide Operating Temperature: Operates continuously in a wide temperature range from -20°C to 70°C.
    🔌 Flexible Installation and Safety​
    • Various Sizes: Available in 12.1-inch, 15-inch, 15.6-inch, and 21.5-inch options.
    • Single Cable Solution (Type-C): Transmits power, touch inputs, and video signals over a single cable, reducing cabling complexity.
    • Hazardous Environment Compatibility (C1D2): Certain models are Class I, Division 2 (C1D2) certified for specialized industrial sectors such as oil and gas refineries and chemical plants. This ensures the hardware does not ignite volatile gases or vapors that may be present under abnormal operating conditions.
    📊 Competitive Edge Features​
    Compared to competitors in the industrial monitor market such as Winmate, Hope Industrial Systems, and Beijer Electronics, Advantech's 1800 nit brightness, IK08 impact resistance, and IP66 sealing rating position these monitors as industry leaders in terms of readability in direct sunlight and durability in harsh outdoor conditions.
