Visibility Isn't Enough in Factories: Why Are We Still Chasing Problems?
For years, manufacturers have strived to make their operations more visible. Machines are connected, sensors are everywhere, and data flows into ERP, MES, CMMS systems, and advanced analytics tools. Leaders have more information about their facilities than ever before. So, why are we still chasing problems?
The problem isn't a lack of data; it's the gap between knowing something is wrong, understanding why it went wrong, and directing the right person to fix the problem.
Consider a familiar scenario: A machine starts behaving abnormally. It generates a signal, but the operator might not know what it means. The maintenance team might not see it immediately, or a supervisor might need to be found. Someone needs to decide who intervenes, find the relevant procedure and necessary parts, and communicate what happened to everyone.
The machine might have only been down for five minutes, but the organization could lose over an hour – and potentially tens of thousands of dollars.
As manufacturers face tighter margins, labor constraints, and pressure to get more output from existing assets, unplanned downtime becomes even more critical. Technology investments that only generate more information won't solve the problem. Manufacturers need technology that helps turn information into action.
Transitioning from Systems of Record to Systems of Action 🎯
Most manufacturing software is primarily designed to record what happened. This is an important function. ERP, CMMS, EAM, MES, and quality systems play valuable roles in capturing operational history, managing transactions, and supporting data analysis. However, the factory floor operates on a different clock.
A technician responding to a faulty asset doesn't need another report about what happened yesterday. They need to know what's happening, what they need to do, and what information is critical to the problem at hand.
This is where connected manufacturing operations solutions find an opportunity to improve.
Manufacturing operations software shouldn't just be another place where production data is stored or visualized. It should function as an operational coordination layer that combines signals from equipment and people with the workflows, information, and resources needed to respond. In other words, the ultimate goal should not just be visibility, but action.
Design for the Work, Not Around the Work 🛠️
There's another often-overlooked part of this equation: the people expected to use these systems.
If an operator has to navigate a complex interface to report a problem, or a technician has to leave the floor to find information embedded in another system, an advanced platform has little value.
The best operational technology should fit how the work is actually done. This means putting relevant information in front of workers at the moment of need. It means minimizing unnecessary data entry. It means making it easy to report an anomaly, access a standard operating procedure, communicate with another department, or see what to look out for next.
This is not just a matter of user experience, but also a matter of data quality.
When technology is cumbersome, employees develop workarounds. Paper forms, spreadsheets, whiteboards, radio calls, and informal handoffs become "shadow systems." These workarounds might keep a shift going, but they also fragment information and make it difficult to understand what's actually happening.
A frontline-centric approach reverses this dynamic. Instead of asking employees to adapt their work to the software, the software adapts to the realities of the work.
Real Value Lies in the Response 💡
This distinction becomes especially important as manufacturers add AI and advanced analytics to their operations. Predicting that a machine might fail is useful. But prediction alone doesn't create value.
Value emerges in the subsequent steps.
When an abnormal condition is detected, can the system identify who needs to intervene? Can it surface the correct procedure? Can it provide relevant equipment history? Can it correlate the problem with parts availability or maintenance resources? Can it record what happened for the organization to learn from the event?
This is the difference between analysis and orchestration. Since manufacturers have already invested heavily in data collection, the next investment decision should help them better utilize that data at the moment of action.
First Stability, Then Standardization and Optimization 📈
The path forward doesn't require every manufacturer to immediately transition to an autonomous factory. In fact, the fundamentals come first.
The first priority should be operational stability: replacing fragmented communication and manual workarounds with a shared, real-time view of what's happening. From there, manufacturers can standardize processes that consistently yield good results. Critical knowledge shouldn't reside only in the heads of a few experienced technicians. Instead, it should be captured, digitized, and made available to the broader workforce.
Only then can manufacturers optimize processes with advanced analytics and AI. Reliable data, standardized processes, and connected workflows form the foundation for technology that can move from identifying problems to recommending (or eventually initiating) the correct response.
This progression is important because manufacturers don't have a technology problem to solve; they have an implementation problem.
They have already connected machines, collected data, and developed increasingly sophisticated analytical capabilities. The next challenge is to integrate all this intelligence with the people who do the work.
The manufacturers who get the most out of their digital investments won't be those with the most sensors, dashboards, or applications. They will be those who can consistently turn a signal into a response.
This is the purpose of modern manufacturing operations software: not just to make the plant more visible, but also more responsive. When technology is built according to how work is actually done on the plant floor, and information arrives in the context and workflow needed to act on it, visibility finally transforms into something more valuable than a dashboard.
This becomes operational performance.
