🚀 Hybrid Connection Solution from Beckhoff for One-Cable Automation!
🔌 The Future of One Cable Automation: ECP and ENP Connectors​
Beckhoff has taken a revolutionary step in industrial automation by expanding its portfolio of ECP and ENP hybrid connectors, which integrate power, signal, and data transmission into a single interface. This innovative hardware supports the "One Cable Automation" philosophy, enabling engineers to create cabinet-free architectures in modular machines and distributed industrial systems.
⚡ Power and Data Integration​
The shift towards decentralized systems necessitates connection platforms that minimize cabling volume while maintaining power distribution and data integrity. The Beckhoff ECP and ENP series address this need by combining standard signaling with power supply. This approach consolidates previously separate channels into a unified data core, reducing the physical space and material requirements for industrial cabling. This hardware forms the technological foundation for cabinet-free architectures like the Beckhoff MX-System, providing connectivity directly at the I/O level on the machine floor.
⚙️ Electrical Specifications and Form Factors​
To meet varying power requirements in industrial applications, the hybrid connector portfolio includes B12, B17, B23, and B40 housing sizes. Electrical contacts are designed for 24 V DC transmission at the I/O level, with high-power configurations supporting up to 630 V AC or 850 V DC. The connectors can manage current capacities up to 72 A, providing the necessary power bandwidth for servo drives and modular machine operations.
🌐 Standardization and Interoperability​
The Beckhoff ECP and ENP series are implemented in accordance with the DIN EN IEC 61076-2-118 standard, which defines international specifications for circular hybrid connectors. The fact that hundreds of thousands of ECP and ENP interfaces are already in use in the field demonstrates the practical applicability of the hardware in operational environments. Compliance with the international standard ensures a uniform interface topology and verified compatibility in multi-vendor industrial networks. The standardization of the connector architecture guarantees supply chain viability and provides the electrical and mechanical reliability required for heavy-duty automation systems.
🔍 Technical Comparison​
The Beckhoff ECP and ENP connector series operate in the industrial hybrid connector market alongside alternatives such as the CONEC hybrid connector portfolio. Both manufacturers offer solutions based on the DIN EN IEC 61076-2-118 standard, include a bayonet locking mechanism, and standardize form factors in B12, B17, B23, and B40 sizes. While Beckhoff specifies voltage transmission up to 630 V AC or 850 V DC and current capacities up to 72 A for modular machines, the CONEC hybrid series also targets decentralized servo drive systems, providing configurations for power classes exceeding 20 kW. Both connector architectures combine power, signal, and data transmission in a single IP67-rated housing, enabling machine engineers to build cabinet-free automation systems that reduce cabling complexity.
