🚀 A New Breath for Industrial Automation from Advantech: UNO-2484V3!
    💡 Next-Gen Edge Computer Takes the Stage!​
    Advantech has introduced the UNO-2484V3, a fanless edge computer designed for industrial automation and Industrial Edge applications. This powerful device was developed to support data-intensive applications such as computer vision and predictive maintenance in demanding industrial environments.
    🧠 Powerful Processor and Memory Architecture​
    • Equipped with Intel Core Ultra (Series 2) 5 and 7 processors (Arrow Lake-U, 15 W).
    • Offers a maximum of 14 CPU cores and 12 MB L3 cache.
    • Dual-channel DDR5-6400 memory support (up to 64 GB with two SO-DIMM slots).
    • Provides hardware-level security with a TPM 2.0 chip.
    🔌 Flexible Connectivity and Expansion Options​
    • One GbE LAN (Intel i219) and three 2.5GbE LAN (Intel i226) ports.
    • Four RS-232/422/485 ports, three USB 3.2 Type-A, and two USB Type-C ports.
    • Support for four independent displays (HDMI 1.4, DisplayPort++, and two USB Type-C outputs).
    • Four M.2 slots (B-key, E-key, two M-key) and an external nano SIM card slot.
    • Integration of two swappable 2.5-inch SSDs and Advantech iDoor expansion modules with an optional second stack.
    ⚙️ Robust Design, Ideal for Field Operations​
    • Compact form factor within the UNO-2000 V3 series (200 × 140 × 55 mm).
    • Fanless design and optimized heatsink for thermal management.
    • 10 to 36 VDC input voltage and -20 °C to 60 °C operating temperature range.
    • Compatible with Windows 11 LTSC and Advantech EdgeLinux operating systems.
    📈 Competitive Advantages​
    Thanks to its 14-core Intel Core Ultra processors and DDR5-6400 memory, the UNO-2484V3 offers 30% to 50% higher memory bandwidth compared to standard platforms using DDR4. Its three native 2.5GbE interfaces exceed the two-port standard found in many competing devices. The four M.2 slots provide superior flexibility for 5G/LTE, Wi-Fi, and high-speed NVMe storage.
