💰 Why CEOs Can't Make Money from AI
Every CEO I know has an AI initiative. But almost none of them can show how much these initiatives contribute to EBITDA.
This isn't a problem with the technology itself. I've been consulting manufacturing and industrial leaders on performance improvement for over 35 years. I've seen many tools clear the "does it work" hurdle, only to get stuck at the "does it make money" hurdle.
AI is doing the same thing right now. Models are good, dashboards are shiny. Pilot projects get funded, scaled, and sometimes turn into press releases.
But in most cases, they don't translate into a quarterly number that the leadership team is willing to defend in front of the board.
I believe this isn't a technology problem; it's a trust problem.
📉 The Chasm Between Adoption and Value
Gartner's 2026 CIO and Technology Executive Survey revealed that only 17% of organizations have deployed AI agents. Yet, over 60% expect to do so within the next two years.
This is one of the steepest adoption curves Gartner tracks. If you read this gap like an operator, it says something unsettling: Industry is scaling intent much faster than proof.
I would ask my colleagues a simpler, more provocative question: Has AI delivered a measurable financial benefit, or has it just changed how busy everyone looks?
It's easy to create "busyness" on the factory floor. Add predictive maintenance alerts, a forecasting model, a chatbot summarizing shift reports, and suddenly there's more activity, more dashboards, more meetings about dashboards.
None of that is the same as lower scrap rates, less unplanned downtime, or genuinely reduced working capital. Activity is not value. Leaders who have spent real time on the shop floor instinctively know the difference. Sometimes, those who don't are the ones evaluating AI from a slide deck.
💡 Why the Constraint Isn't the Model
What I believe after walking factory floors in manufacturing, transportation, energy, and many other sectors is this: Technology is rarely the bottleneck anymore. The constraint is decision quality; that is, whether the people receiving the model's output trust it enough to act on it, to change a habit, or to alter a standard operating procedure.
This trust doesn't automatically emerge because the model is accurate. It emerges when three things are true:
- Governance Must Be Real: A model recommending a maintenance schedule or a pricing change must have an owner, a review cadence, and a documented failure mode. Just like the rigor a factory would apply to a new supplier or a capital project.
- Humans Must Be Involved in the Process: The people closest to the work must not just receive the tool, but be part of building it. A model no one trusts won't be used, and an unused model, no matter how sophisticated, generates zero EBITDA.
- Leadership Must Measure the Right Thing: Leadership must be willing to measure what they are actually trying to change (cost, cycle time, quality, cash) rather than a proxy metric like "number of use cases deployed" or "percentage of employees trained on AI."
🎯 What Does Decision Quality Look Like?
Manufacturers who are getting real value from AI didn't start with the most ambitious use case. They started with a narrow, high-friction decision where the cost of a wrong decision was well understood and easily measurable.
They built governance and trust on something small enough to be validated, then scaled once the model had earned credibility with the humans who had to live with its recommendations. This sequencing is more important than the sophistication of the underlying algorithm.
It's a less exciting story than "we deployed enterprise-wide generative AI." But it's also the version that shows up in the numbers.
Underneath this is an organizational discipline that's easy to overlook: Someone must own the model the way they own a piece of equipment. That means a specific person who is accountable for its accuracy, has a schedule to check if its recommendations are still valid as conditions change, and a clear process for what happens when it's wrong.
🤔 The Question I'd Ask My Colleagues
So, what I want to ask other manufacturing and industrial leaders, not rhetorically, but as a real internal check, is this: When you strip out the dashboards, the training completion rates, and the press releases, what did AI do to your EBITDA this year?
Not what it could do. Not what the roadmap says. What did it do?
I suspect most honest answers will fall somewhere between "not much yet" and "we don't know how to measure it." That's not bad; new capabilities take time to translate into results, and manufacturing has not been an industry that confuses hype with cash flow.
