🤖 The New Brain of Smart Factories: AIR-075
Aaronn Electronic and Advantech have introduced the AIR-075, a groundbreaking Edge AI inference platform for industrial automation and robotic systems. With processing power based on the Blackwell architecture, this system eliminates latency by processing AI workloads directly at the machine level, reducing cloud dependency.
🧠 Powerful Architecture, Limitless Capabilities
- NVIDIA Jetson T5000 and T4000 Modules: Powered by the Blackwell GPU architecture, these modules deliver unprecedented performance.
- The Heart of the T5000: A 14-core Arm Neoverse V3AE processor, 2,560 GPU cores, and 96 Tensor Cores provide up to 2,070 TFLOPS of FP4 sparse AI performance. Supported by 128 GB of LPDDR5X memory, this power is ideal for generative AI and agent-based workflows.
- T4000 Option: For those seeking a more scalable solution, it offers 1,200 TFLOPS of performance, 64 GB of memory, and 1,536 GPU cores.
- Industrial Reliability: Verified on-module DRAM used in the modules guarantees long-lasting and reliable operation.
⚡ Seamless Data Flow with High-Bandwidth Connectivity
- 10GbE Network Support: The AIR-075 offers native 10GbE network connectivity for high-bandwidth data acquisition in factory automation. The T5000 model has four, and the T4000 model has two RJ45 10GbE ports.
- PoE Support: With optional IEEE 802.3af PoE support, power and data can be supplied over a single cable.
- Direct Machine Integration: Two RS-232/422/485 serial interfaces, additionally two CAN bus interfaces in the T5000 variant, and an 8-bit digital I/O interface allow direct communication with sensors and robotic controllers.
🛠️ Flexible Deployment and Expansion Opportunities
- Compact Design: The hardware chassis, measuring 235.8 × 174 × 59 mm, supports wall mounting and operates with a 19 to 36 V DC input voltage.
- Power Efficiency: The T5000 configuration consumes power from 13.2 W at standard OS idle to 156 W at maximum load.
- Enhanced Security: The TPM 2.0 module provides hardware-based security and cryptographic integrity.
- Modular Expansion: Communication and local data storage can be easily expanded thanks to M.2 slots supporting NVMe SSDs, Wi-Fi, and 5G connectivity.
🌟 Designed for the Factories of the Future
The AIR-075 represents the next generation of NVIDIA Jetson Thor-based systems. In contrast to the previous Jetson AGX Orin platforms' performance of up to 275 TOPS, Blackwell-based Thor systems deliver performance in the TFLOPS range at FP4 precision, bringing generative AI and Visual-Language Models (VLM) directly to the Edge. This platform stands out from its competitors with its native 10GbE interface density and integrated CAN bus capabilities.
