🤖 Revolutionary Innovation from Rodriguez: 7th Axis Power for Cobots with Thomson Movotrak CTU! 🚀
Ahmet Ă–.
    ✨ The Horizon of Cobots Expands: Rodriguez Introduces Thomson Movotrak CTU!​
    Rodriguez has introduced the Thomson Movotrak™ Cobot Transfer Unit (CTU), a groundbreaking solution for industrial cobots. This innovative system adds a mobile 7th axis to cobots, extending their working range up to 10 meters. Now, a single cobot can flexibly perform tasks at multiple stations on a production line, thereby maximizing system utilization and eliminating retooling times.
    🛡️ Autonomous Safety and Easy Programming​
    The Movotrak CTU is the only 7th axis on the market with autonomous collision detection. This feature allows it to detect potential collisions while in motion and stop automatically, enhancing safety in environments with high human-machine interaction. Furthermore, thanks to its integrated Freedrive function, operators can manually guide the robot along the axis and quickly record positions, shortening teaching and changeover times.
    The system is built on two robust linear units providing maximum torque capacity and is offered as a complete solution including the motor, gearbox, and control cabinet. Typical application areas include machine tending, large area welding and dispensing, material handling, and quality control inspections of large components.
    🏭 A New Era in Manufacturing: Flexibility and Efficiency​
    In modern manufacturing, cobots were traditionally limited to stationary tasks due to their fixed bases and restricted reach. However, with the shift to high-mix, low-volume (HMLV) production, the ability to redeploy a single cobot between multiple CNC machines, palletizing areas, or inspection stations significantly accelerates the return on investment (ROI).
    In the past, integrating a standard linear transfer unit created new pinch and crush hazards that eliminated the collaborative degree of the cobot, necessitating the installation of physical safety fences. The Movotrak CTU integrates collision detection directly into the 7th axis, maintaining a fence-free, collaborative environment. This allows human operators and automated lines to safely share the same space during large-scale production tasks.
