🌟 Compact Power, Limitless Vision!
Aetina has introduced AIE-VN34/44 and AIE-VO24/34, palm-sized in-vehicle AI systems that bring a fresh perspective to the world of mobility! Powered by NVIDIA Jetson Orin NX and Orin Nano modules, these devices offer up to 100 TOPS of AI performance, while revolutionizing environmental perception with four GMSL2 camera connections.
🛣️ Designed for Smart Transportation and Industrial Automation
These compact and robust systems are ideal for applications where space and reliability are critical, such as smart transportation, autonomous mobile robots (AMR), and industrial automation. By processing real-time, high-quality multi-camera video streams, they pave the way for AI-powered vision systems in a wide range of environments, from smart cities to industrial facilities.
👁️ Compact Computing for Multi-Camera AI Vision
- High Performance: Up to 100 TOPS of AI performance with NVIDIA Jetson Orin NX (8GB/16GB) and Orin Nano (4GB/8GB).
- Compact Design: A palm-sized chassis measuring 136.3 x 132 x 63 mm.
- Wide Field of View: Long-distance, low-latency multi-camera streaming and 360-degree environmental perception thanks to four GMSL2 (Fakra-Z) ports.
- Easy Integration: Plug-and-play support with Aetina-approved GMSL2 adapter cards and camera modules, with image transmission up to 15 meters.
💪 Robust and Fanless Design for Field Operations
The AIE-VN34/44 and AIE-VO24/34 are specially designed for demanding mobile and industrial applications:
- Durability: Passed MIL-STD-810H shock and vibration tests, E-Mark (E24) certified.
- Wide Operating Temperature: Stable operation between -25°C and +55°C thanks to its fanless architecture.
- Secure Power Management: 9–36V DC wide voltage input and integrated Ignition Power Control for protection against voltage fluctuations.
- Flexible Connectivity: Isolated CAN FD, GPIO/RS-232, Gigabit Ethernet (GbE), USB 3.2, HDMI, M.2 M-Key storage, and optional M.2 E-Key wireless expansion.
🌐 AI Vision in Transportation, Robotics, and Industrial Automation
These systems transform visual data into actionable insights in many areas, such as blind spot detection for commercial vehicles, obstacle avoidance for AMRs, real-time defect inspection in production lines, and security monitoring in smart retail environments.
💬 Statement from Aetina Executive
James Ho, Product Division Manager of Edge Computing at Aetina, stated, "As real-time, multi-camera sensing becomes the perception layer for AI agents operating in vehicles, AMRs, and industrial equipment, customers need robust and production-ready edge computing solutions that can withstand field challenges. Aetina's palm-sized in-vehicle edge AI systems combine four-camera GMSL2 support, automotive-grade certification, and NVIDIA Elite Partner-backed BSP into one robust multi-vision platform, helping customers simplify integration and accelerate intelligent vision deployment at the edge."
🚀 Now in Production!
The AIE-VN34/44 and AIE-VO24/34 are ready for mass production with BSP support built on NVIDIA JetPack 6.2. NVIDIA JetPack 7.2 support will be added soon.
