🚀 New Generation PoE++ Injector from Antaira: Power and Data in One Cable!
Ahmet Ă–.
    🔌 Antaira Introduces 100W AC-Powered PoE++ Injector for Industrial Environments​
    Antaira Technologies has launched its new, robust PoE injector, model INJ-0201G-bt-AC-100-T, which delivers reliable performance even in harsh conditions. This device can be plugged directly into a standard wall outlet thanks to its integrated 100-240VAC power input.
    ⚡ Solution for High Power Needs​
    The INJ-0201G-bt-AC-100-T provides IEEE 802.3bt (PoE++), 95W High PoE, or 100W four-pair (4PPoE) output over a single Ethernet cable, bringing high-wattage PoE capabilities to legacy non-PoE network infrastructures. This allows high-power-consuming devices such as motorized PTZ cameras, Wi-Fi 6, and Wi-Fi 7 access points to be easily powered.
    🌡️ Robust Design for Harsh Environments​
    This fanless, IP30-rated injector is designed to operate flawlessly in extreme temperatures ranging from -40°C to 75°C. It offers both high-power PoE and Gigabit data (10/100/1000TX) support, accelerating installation and reducing cabling requirements in industrial automation, security, and transportation applications.
    đź’ˇ Why It Matters?​
    The increasing power demands of next-generation network devices have exceeded the 30W limit of older PoE+ standards. The IEEE 802.3bt (PoE++) standard solves this problem by delivering up to 100W of power using all four twisted pairs of an Ethernet cable. In industrial and remote environments, where centralized DC power infrastructure is often absent, an AC-powered, temperature-hardened injector eliminates the need for separate and bulky external power supplies. This enables system integrators to quickly deploy high-wattage devices with standard network switches and existing AC outlets.
