🚀 July 2026 Product Review: The World of Sensors! 🚀
Elif Özaksu
  • Altanlar
    AutomationDirect Proximity Sensor​
    AutomationDirect's AchieVe PAM-AP-1A inductive proximity sensor features a compact design with a 12 mm diameter and a 35 mm body. It stands out with its nickel-plated brass body, PNP, N.O. output, 2 mm sensing distance, and 3 kHz switching frequency. Its IP67 rating and pigtail wiring allow for easy installation. It has a repeatability accuracy of 0.1 mm for flush mounting and 0.2 mm for non-flush mounting. With its PBTP (polybutylene terephthalate) surface and compliance with the IEC 60947-5-2 shock/vibration standard, it promises durability.
    Festo Force Sensor​
    Festo's SKDA IP67-rated sensor precisely determines tensile and/or compressive forces in machines and systems. It is ideal for static and dynamic measurement tasks directly in the force flow. It is used in electric screw presses and general force measurement applications. The SKDA sensor, made of CrNi steel, stands out with its corrosion-resistant structure. It features high shock and vibration resistance, good repeatability, and easy mounting. It has a force measurement range of up to 100 kN and an operating voltage of 10 to 30V.
    Sick Photoelectric Sensors​
    Sick W12 photoelectric sensors provide reliable object detection in industrial environments. Their robust die-cast zinc housing offers protection against mechanical and thermal influences. Resistant to optical interference such as ambient light, these sensors enable quick commissioning thanks to the BluePilot user interface and IO-Link. Application-oriented variants are available that provide high detection reliability even for transparent, irregular, reflective, high-contrast, perforated, or depolarizing objects.
    Siemens Temperature Sensor​
    Siemens Sitrans TS500 temperature sensors are designed for various measurement applications in harsh environments. Their modular design, which includes a protective tube made of pipe or solid material, an extension, a connection head, and an optional transmitter or display, allows for the use of standard components. Intrinsically safe or flameproof designs are also available for use in hazardous areas. Explosion protection is provided with different ignition protection types such as Ex i (IS), Ex e (NI), Ex d (XP), and Ex t (DIP).
