🚀 Modular Edge Computing Expansion Platform for Duro Edge Series: DockInfinity!
SĂĽeda Asil
    đź’ˇ A New Era in Industrial Computing: DockInfinity​
    Nexcom is revolutionizing areas such as automation, machine vision, and logistics with its DockInfinity platform, designed for industrial computers. This modular system easily expands PCIe and storage hardware, enhancing the capabilities of existing Duro Edge series devices.
    🛠️ Flexibility with Side Panel Expansion​
    DockInfinity offers the ability to increase processing power, network, and storage capacity through modules added to the side panel of box-type PCs. This provides flexibility in applications such as optical inspection, autonomous mobile robots, and smart warehouse equipment, without needing to change the core hardware.
    ⚙️ Technical Details: PCIe 4.0 and Thermal Management​
    Industrial edge computers face increasing workloads with the continuous development of artificial intelligence and machine vision algorithms. DockInfinity transforms compact PCs into multi-slot industrial systems by directly attaching to the side panels of existing Duro Edge chassis. This design facilitates hardware upgrades without requiring a full chassis replacement.
    The platform integrates specialized add-on cards using standard PCIe 4.0 connection interfaces and supports PCIe x1, x4, x8, x16 form factors. For intensive AI tasks, active cooling systems include dedicated ventilation and internal fans to dissipate heat generated by high-power graphics processing units.
    📦 Hardware Configurations and Interface Features​
    • DockInfinity-2R8: Provides connectivity for a single PCIe 4.0 x16 or dual PCIe 4.0 x8 cards. Ideal for RAID controllers, high-density LAN interfaces, multi-port USB, and HDMI output cards.
    • DockInfinity-R16F: Accommodates a single PCIe 4.0 x16 high-performance graphics accelerator with a dual-slot mechanical footprint and integrated cooling fan. Prevents thermal throttling during intensive parallel processing workloads.
    • DockInfinity-E4X1: Offers a single PCIe 4.0 x4 slot for entry-level edge gateway expansion; suitable for PoE cards, frame grabber cards, and specialized industrial I/O.
    • DockInfinity-2S: A dedicated expansion kit for two SSDs. Equipped with two standard 7-pin SATA connectors and dedicated SATA power interfaces, supporting hardware RAID 0 and RAID 1 modes for data redundancy or accelerated throughput.
    🏭 Industrial Integration and Workloads​
    Pairing specific Duro Edge base units with appropriate expansion modules provides targeted operational performance according to deployed industrial environments.
    The NDiS B562 industrial system with an Intel Core processor, combined with the DockInfinity-R16F module, performs high-efficiency AI inference and continuous image processing tasks in automated optical inspection setups. The additional PCIe 4.0 x16 throughput and dedicated active cooling maintain the high data transfer rates required for high-resolution frame grabbers and graphics processing units.
    For lightweight edge processing and IoT gateway tasks, the NDiS B340 system pairs with the DockInfinity-E4X1 module. This combination provides the additional connectivity required for autonomous mobile robots and warehouse management equipment, allowing direct interfacing with multi-camera vision sensors, fieldbus networks, and local storage devices.
    📊 Technical Comparison and Advantages​
    Industrial edge expansion platforms are typically evaluated in terms of bus bandwidth, signal latency, thermal dissipation capacity, and mechanical integration efficiency. Standard PCI Express 4.0 offers approximately 31.5 GB/s bidirectional bandwidth on an x16 interface.
    DockInfinity's direct side panel mounting provides a native PCIe 4.0 connection directly to the system motherboard with full bus bandwidth and sub-microsecond latency. External expansion boxes often rely on Thunderbolt 4 or bridged PCIe connections, which limit data transfer speeds and introduce additional signal overhead.
    DockInfinity's active-cooled direct chassis-mounted expansion modules support add-on cards drawing 75W or more, allowing for higher thermal power dissipation limits, which is critical for sustaining continuous workloads in modern edge AI graphics accelerators.
