đź’ˇ Powerful Solution from Toshiba for Industrial Automation
Toshiba has introduced the TB67S531FTG, a new two-phase stepper motor driver integrated circuit specifically designed for industrial automation and commercial equipment. This high-voltage bipolar integrated circuit aims to prevent motor stalls by increasing resistance to electrical noise.
⚙️ Seamless and Precise Operation
In industrial environments, electrical interference can negatively impact the precise operation of motors. The TB67S531FTG addresses this issue by regulating the electrical current in each motor phase through its special phase input architecture. This minimizes sudden current fluctuations, preventing motor stalls and ensuring continuous and consistent positioning in sensitive electromechanical systems.
⚡ High Performance, Low Heat
This integrated circuit supports motor output voltages up to 40V and driver currents up to 2.0A. Thanks to its low typical on-state resistance (RDS(ON)) of 0.8Ω, the amount of heat generated during continuous operation is significantly reduced. This increases overall system energy efficiency and thermal performance while reducing the need for external cooling. Furthermore, its compact QFN32 package, measuring 5.0 mm x 5.0 mm, occupies less space on printed circuit boards.
🛡️ Integrated Control and Safety
The TB67S531FTG combines several discrete components into a single package to simplify the architecture of motion control systems. It includes an integrated current sensing circuit for constant current regulation and a charge pump circuit necessary to drive the internal H-bridge output stage. By supporting various excitation modes, it allows engineers to configure step resolutions from full step to quarter step. Additionally, standard hardware protection mechanisms such as overcurrent detection, thermal shutdown, and undervoltage lockout prevent system failures in the event of electrical malfunctions.
🔍 Technical Details and Competitive Analysis
This integrated circuit is positioned at a performance level that can compete with industry standards such as the Texas Instruments DRV8825 and Allegro MicroSystems A4988. While older driver architectures relied on external sensing resistors, modern solutions like the TB67S531FTG integrate this sensing capability directly into the silicon, saving board space. The 0.8Ω RDS(ON) value is competitively positioned in terms of thermal efficiency, considering that traditional drivers in the 2.0A output class typically have resistances of 1.0Ω or higher. While this model offers support up to quarter-step resolution, specialized drivers designed for ultra-precise optical or medical systems can offer micro-stepping capabilities up to 1/256 step.
