Elif Özaksu
🚀 Balluff Breaks New Ground in Industrial Automation!
Balluff has introduced SmartLight Black Line signal towers, bringing a fresh perspective to its automation portfolio. This innovative product stands out with its "Ultimate" mode, which provides highly visible process signaling and integrated direct control.
👁️🗨️ Clear Visibility Even at Long Distances
The SmartLight Black Line series is designed to offer clear status communication even in complex production environments. This allows operators to easily monitor system status and optimize equipment uptime, even in changing light conditions and from long distances.
⚙️ Process Optimization and Advanced Control Modes
Industrial automation systems require rapid visual feedback to prevent delays and ensure occupational safety. The SmartLight Black Line meets these requirements by combining physical visibility improvements with advanced electronic control architectures:
[]High-Contrast Visibility: Color segments are clearly distinguishable even in factory environments with high ambient light or large production areas.
[]Integrated Flasher Function: Includes a special flasher module that emits high-intensity visual pulses to alert operators in noisy or visually busy environments.
- Direct Process Control (Ultimate Mode): This mode enables direct, real-time control of individual signal segments via active process data streams. This reduces the parameterization steps required in traditional setups and directly links indicator behavior to machine telemetry.
🎯 Target Applications and System Integration
The SmartLight Black Line is ideal for all automated environments requiring rapid operational feedback loops. It is particularly suitable for high-throughput assembly lines, multi-status machine setups, safety-critical production zones, and large-scale facility layouts. For system integrators and plant managers, it aims to increase overall equipment effectiveness by providing real-time process visibility and deep control loop integration.
💡 Technical Details: IO-Link and Ultimate Mode
Traditional signal towers rely on single-stage incandescent or LED lights, which require separate physical lines for each color layer and limit indicator flexibility. The SmartLight platform replaces this analog structure with a software-configurable multi-segment LED array managed via the open standard IO-Link communication interface.
The Ultimate mode allows the system to process process data words directly from the main Programmable Logic Controller (PLC) without the need for complex non-cyclic parameter blocks. The internal controller converts raw bytes into instantaneous physical variables such as dynamic color changes, level indicator fills, or localized segmentation boundaries.
This allows the Ultimate mode to eliminate the typical software configuration delays of standard operating modes, enabling the signal tower to function like a live analog level indicator. Liquid tank levels, internal pressure parameters, or precise temperature gradients can be directly displayed on the factory floor.
