In the world of industrial automation, precision and efficiency are always paramount. Especially for medium-scale manufacturing applications, a new generation of motion control solutions is poised to revolutionize this field. Kollmorgen's newly launched 8-axis motion controller and high-voltage servo drive bring together flexibility and performance on production lines.
βββββββββββββββββββββββββ
π‘ New Generation Controller: PCMM2G Essentials
Kollmorgen is expanding its automation portfolio with the PCMM2G Essentials, an 8-axis programmable motion controller. This compact device offers a centralized solution for applications requiring indexing, positioning, and multi-axis coordination. It is specifically designed to meet advanced motion control needs in automotive parts manufacturing, material handling, and logistics facilities.
[]Compact Design: Occupies minimal space on the DIN rail, simplifying cabinet integration.
[]Flexible Programming: Can be programmed with standard IEC 61131-3 languages or visual-based Pipe Network.
[]Centralized Control: Provides synchronized coordination for up to eight axes.
β‘ High Power, High Efficiency: 480V Servo Drive
Accompanying the new controller, the 4 kW high-voltage servo drive is ideal for heavy-duty machinery and logistics infrastructures. This drive supports 240 to 480 VAC three-phase input, ensuring direct compatibility with standard industrial electrical grids in North America and Europe.
- ]Transformerless Operation: Eliminates the need for an external step-down transformer. This simplifies electrical panel design and reduces energy losses.
[]High Power Output: Provides up to 4 kW of power, suitable for high-torque applications.
[]Energy Efficiency: Minimizes transformer-induced heat generation and energy losses.
π€ Integrated Automation Architecture
The 8-axis controller and 480V servo drive seamlessly integrate into Kollmorgen's extensive industrial automation architecture. By combining servo motors, drives, and control software within a single ecosystem, it enables OEMs (Original Equipment Manufacturers) to perform external controller control and complete system programming. Distributors like INMOCO in the UK support regional distribution by offering engineering consultancy on motion system design, load sizing, and component specification.
π Market Positioning and Technical Superiority
In the industrial automation sector, 8-axis motion controllers target a specific mid-segment, filling the gap between single-axis drives and complex PLCs (Programmable Logic Controllers) that manage dozens of axes. Compared to competitors like the Rockwell Automation CompactLogix series or the Omron NX1, the key differentiators of this hardware are processing cycle times, deterministic network protocols like EtherCAT, and native programming environments.
480V, 4 kW servo drives are standard in heavy manufacturing because higher voltages minimize cable thickness and current draw for high-torque applications. The ability to directly accept 480V three-phase input puts this servo drive in direct competition with hardware such as the Siemens SINAMICS S210 and Allen-Bradley Kinetix 5500. A critical measurable feature in this class is the elimination of the isolation transformer; this provides significant physical cabinet space savings and reduces thermal dissipation requirements within enclosed electrical enclosures.
These new products from Kollmorgen represent a significant step for businesses seeking smarter, more efficient, and more integrated solutions in industrial automation. Thanks to advanced control capabilities and high power efficiency, they promise a new level of optimization in production processes.
