Quality control in production lines, especially in barcode verification, is entering a new era. OMRON Automation is revolutionizing this field with its VHV5-SRV Barcode Verification System. This next-generation solution ensures the real-time and inline quality of 1D and 2D codes in critical sectors such as life sciences, pharmaceuticals, food, automotive, and aerospace. Now, ISO-compliant 100% barcode inspection is possible at production speeds, up to 1,200 parts per minute!
🔍 Make a Difference with Continuous Quality Monitoring
Traditionally, barcode quality control in manufacturing was limited to manual, offline sampling performed at the beginning or end of production. This method carried the risk of detecting gradual deteriorations in print quality or unreadable codes only after an entire batch had been processed and shipped. The VHV5-SRV completely changes this outdated approach.
The system analyzes each barcode as it is printed or applied, allowing quality engineers to immediately detect deviations and adjust marking parameters before defective products advance within the facility. This provides the necessary data continuity for part and packaging history, especially for highly regulated industries.
📊 Technical Approval and International Standards
To ensure repeatable readability throughout the digital supply chain, code quality is evaluated according to defined international standards. The VHV5-SRV verifies linear 1D barcodes against the ISO/IEC 15416 standard, and two-dimensional 2D matrix codes against the ISO/IEC 15415 standard. For direct part markings (DPM) applied to components in sectors like automotive and aerospace, it uses the ISO/IEC TR 29158 grading criteria.
Beyond geometric and optical analysis, the device verifies data structures and syntax according to global GS1 requirements, thereby preventing formatting errors before shipment. To maintain compliance with ISO/IEC verification standards, the system is calibrated using an external third-party calibration card, ensuring objective, standardized grading.
⚡ High-Speed Inspection and Optical Flexibility
The camera system is designed to perform verification at high production speeds of up to 1,200 parts per minute, ensuring that quality inspection does not create a bottleneck on the production line. To reduce variations caused by complex surface geometries, the hardware supports both internal and external illumination configurations. This flexibility enables high-contrast imaging on reflective, curved, or irregular surfaces, such as metallic automotive parts or flexible food packaging. By incorporating both decoding and certified verification capabilities in a single unit, the system can directly replace existing barcode readers during factory modernization.
⚙️ Competitive Analysis: OMRON VHV5-SRV vs. Cognex DataMan 475V
In the industrial inline barcode verification market, the OMRON VHV5-SRV competes directly with established solutions like the Cognex DataMan 475V series. Both platforms support key international standards such as ISO/IEC 15415, 15416, and TR 29158.
The fundamental technical difference lies in the optical architecture and processing pipeline. While the Cognex platform uses a fixed four-quadrant 45-degree illumination configuration to meet the physical arrangement criteria of ISO standards, OMRON employs integrated transformation software and Flat Field Correction for surface correction. This digital approach dynamically compensates for illumination and pixel variations across the entire field of view on irregular surfaces.
In terms of operational efficiency, the VHV5 platform, thanks to its multi-core processors, achieves up to 4,000 parts per minute for standard decoding and up to 1,200 parts per minute for fully certified inline verification according to ISO criteria. This high verification threshold makes the system ideal for fast packaging and assembly lines where 100% inspection is required without mechanical delays.
The OMRON VHV5-SRV elevates production quality to the next level, helping businesses both increase efficiency and comply with international standards. This innovative system is poised to become an indispensable part of future smart factories.
