Alper AktaΕ
EndΓΌstri Vadisi
In the world of manufacturing, efficiency and cost control are more critical than ever. Rising operating costs, strict production targets, and limitations in engineering resources are constantly pushing manufacturers to seek new solutions. It is precisely at this point that Mitsubishi Electric Europe has introduced DataNavigateApp, a brand-new browser-based application designed to increase visibility on the shop floor and make sense of production data.
βββββββββββββββββββββββββ
π From Data Chaos to Meaningful Information
While factories often collect massive amounts of machine data, they struggle to translate this information into practical operational insights. DataNavigateApp aims to overcome this challenge by providing manufacturers with a better understanding of critical areas such as machine performance, downtime, and energy consumption.
βοΈ Simple Setup, Monitoring from Anywhere
This innovative application is specifically designed for Mitsubishi Electric's MELSEC iQ-R series C Intelligent Function Module. This browser-based solution, which can be easily installed via an SD card, provides visualization at the production level, representing the first step towards broader factory visualization, IoT, and digital transformation initiatives.
[]Simple Setup: Can be configured via an intuitive web browser, requiring no programming knowledge.
[]Monitor from Anywhere: Machine status and production trends can be viewed remotely from PCs or tablets without the need for dedicated HMI hardware.
- Easy Data Collection: Supports data collection from both Mitsubishi Electric and third-party PLC environments via standard industrial communication protocols.
π Compatible with Existing Systems, Flexible Solution
DataNavigateApp can easily collect data from Mitsubishi Electric and other manufacturers' PLCs without extensive integration or modifications to existing PLC programs. This allows for seamless deployment even in production environments with equipment from different suppliers or where legacy systems are in use.
The application is designed to support gradual adoption. Manufacturers can start by monitoring a single machine or production line and then scale the same approach to broader operations.
π‘ Lower Costs, Higher Efficiency
Daniel Sperlich, Strategic Product Manager at Mitsubishi Electric, states that the application lowers the barrier to accessing production analytics. "Manufacturers can increase the visibility of machine performance, identify opportunities to improve output stability, reduce downtime, better understand energy behavior, and lower operating costs, without the need for large-scale software projects or expert programming knowledge."
The platform offers solutions to common production problems such as output instability, unplanned downtime, increased energy consumption, and performance degradation. By visualizing equipment operating status and operational trends, identifying factors affecting uptime, highlighting wasted power consumption, and supporting predictive maintenance, it enables teams to prioritize improvements more effectively and respond faster to emerging issues.
π Instant Decision-Making with Intuitive Dashboards
Information is visualized through intuitive graphical dashboards. This allows users to compare operational data side-by-side across different timeframes, machines, or production conditions. This feature helps teams identify trends, prioritize improvement opportunities, and respond faster to operational issues. The result is faster decisions, clearer priorities, and measurable improvements in machine performance.
