🚀 New Hybrid Connectivity in Industrial Automation: B23 Series from binder!
Ahmet Ă–.
    An innovative solution that will put an end to wiring complexity in the world of industrial automation is at our doorstep! binder, a leading manufacturer of circular connectors, has introduced its new B23 hybrid connector series, which combines power supply and shielded data transmission in a single compact structure. This series is poised to revolutionize industrial systems by achieving Ethernet transmission speeds of up to 100 Mbit/s.
    đź’ˇ One Cable Automation: Power and Data Together​
    The B23 series is designed to support One Cable Automation architectures in decentralized industrial systems. This allows for simultaneous power and data transmission over a single cable connection. This integrated approach simplifies installation, significantly reducing wiring costs and potential error risks.
    ⚙️ Simplified Wiring, High Performance​
    In today's industrial automation environments, especially in robotics, modular production systems, and servo drive applications, simplified wiring, reduced installation complexity, and higher communication performance have become increasingly in demand. The binder B23 series provides a strong answer to these demands by combining high power transmission and reliable industrial communication in a single interface.
    🛠️ Key Features and Advantages​
    The prominent features of the B23 connector clearly demonstrate the advantages it offers for industrial applications:
    • []High Power Density and Reliable Data Communication: Combines two critical functions in a single connector.
      ]One Cable Automation: Power and data at a single connection point.
      []Power Transmission: Current capacity of 28 A up to 630 V.
      ]Data Transmission: Shielded Ethernet / EtherCAT compliant with Cat5 standard, speeds up to 100 Mbit/s.
      []Fast Installation: Easy assembly with a bayonet quick-locking system.
      ]Easy Assembly: Screw clamp termination technology for field use.
      []Standardization: Compliance with IEC 61076-2-118 standard for manufacturer-independent compatibility.
    đź”§ Flexible Installation Options​
    binder offers the B23 connector both as a field-mountable solution and as a panel-mount version for device integration. Additionally, extra variants such as single-wire termination and through-hole technology contact configurations are available for different installation requirements. This flexibility allows engineers and designers to choose the most suitable solution for their projects.
    🏭 Application Areas​
    The B23 connector family is designed for a wide range of applications, especially in automation technology. Typical areas of use include:
    • ]Drive systems and servo motors
      []Decentralized automation systems
      ]Modular machine and plant concepts
    • Robotics and flexible production systems
    binder's B23 hybrid connector series takes a significant step forward in industrial automation by reducing wiring complexity, simplifying installation, and increasing system performance. This innovative solution has the potential to enhance the efficiency and flexibility of modern production facilities.
