Ahmet Γ.
Integrated Mechatronic Ecosystems for Industrial Automation and Mobile Robotics π€π‘
In today's industry, groundbreaking developments in automation and mobile robotics are reshaping production processes. At the heart of this transformation are mechatronic ecosystems. Bonfiglioli offers comprehensive solutions, including modular drive systems, functional safety configurations, and predictive maintenance electronics, to optimize intralogistics operations.
βββββββββββββββββββββββββ
π§ Modular Drive Systems and Functional Safety Integration
At SPS Italia, Bonfiglioli introduced an integrated mechatronic ecosystem combining geared motors, variable frequency drives, condition monitoring architectures, and advanced automation software. These hardware and software components address operational requirements in automated intralogistics, automated guided vehicles (AGVs), autonomous mobile robots (AMRs), and continuous packaging processes.
[]High-Performance Drives: Featuring integrated functional safety architectures with Basic, Standard, and Motion options.
[]Supported Safety Parameters: Include Safe Torque Off (STO), Safe Stop 1 (SS1), Safe Brake Control (SBC), Safe Limited Speed (SLS), Safe Limited Position (SLP), and Safe Operating Stop (SOS).
[]FSoE Integration: Reduces wiring complexity by eliminating the need for external safety relays.
[]General Purpose Drives: Utilize a standard variant-based engineering concept for rapid configuration and reduced engineering time.
π Precise Motion Control for Mobile Robotics
The low-voltage planetary servo gearmotor platform, designed for mobile robotic traction and steering, is ideal for shuttles, AGVs, and AMRs. Capable of seamless operation in 24 or 48-volt direct current (DC) battery architectures, this unit combines a precise planetary gearbox with a servomotor.
[]Compact Design: Adapts to the confined spaces of mobile robot chassis.
[]High Torque Density: Provides the necessary power for autonomous navigation and dynamic load handling.
[]Positional Accuracy: Optimized for applications requiring precise positioning.
π Mechatronic Synchronization in Smart Intralogistics
Automated material handling equipment such as palletizers, flowpack systems, and vertical storage lifts utilize synchronous servomotors paired with precision planetary, helical-bevel, or parallel shaft gearboxes. For roller conveyor applications, the drive system, comprising an IE3-rated asynchronous electric motor with a coaxial gearbox and a modular frequency inverter, optimizes mechanical efficiency in continuous duty cycles.
- ]Synchronous Servomotors: Offer high precision and efficiency.
[]Modular Frequency Inverters: Ensure optimal performance in continuous duty cycles.
[]Decentralized Architectures: Support localized motion control via sensorized inverters combined with synchronous reluctance motors.
π Dedicated Electronics and Network Diagnostics
The industrial electronics portfolio, developed by Bonfiglioli Group company Selcom, covers PLCs, peripheral sensors, DC converters for battery applications, and induction heating generators. A new industrial PC is designed to manage up to six isolated communication networks simultaneously with seven Gigabit Ethernet ports.
[]Advanced Industrial PC: Offers high bandwidth for complex network topologies with seven Gigabit Ethernet ports.
[]Multiple Connection Points: Includes one commissioning port, four USB interfaces, and one display port.
π¬ Telemetry and Predictive Maintenance Infrastructure
To reduce unplanned downtime in high-efficiency machinery, the distributed Industrial Internet of Things (IIoT) platform uses integrated wireless sensors to capture thermodynamic and kinematic variables. By mounting accelerometers, magnetometers, and temperature functions directly onto gearboxes and motors, the network collects real-time performance telemetry.
[]Integrated Wireless Sensors: Collects thermodynamic and kinematic data.
[]Predictive Maintenance Algorithms: Detects early mechanical degradation before component failure.
βοΈ Software Architecture for Lifecycle Management
Proprietary automation management software integrates hardware configuration, remote monitoring, and diagnostics into a unified digital interface. An integrated electronic management package handles parameterization and real-time monitoring for modular drives. Concurrently, the IoT manager oversees network architecture, remote firmware deployment, and field data configuration.
[]Integrated Electronic Management Package: Provides parameterization and real-time monitoring for drives.
[]IoT Manager: Manages network architecture and remote firmware deployment.
[]Embedded Sizing Algorithms: Determines drive system components by evaluating application variables such as dynamic load, rotational speed, and duty cycle.
[]Efficiency Module: Measures expected energy consumption and transmission losses between different motor-drive combinations.
These integrated mechatronic approaches are key to enhancing efficiency, safety, and sustainability in modern industrial automation and mobile robotics applications.
