ADLINK Unleashes Physical AI at COMPUTEX 2026
    The future of industrial automation is being shaped by the integration of artificial intelligence with the physical world. At COMPUTEX 2026, ADLINK showcased groundbreaking innovations in "Physical AI" with unified hardware deployment matrices, spanning from hardware controllers to intelligent displays and robotic systems. This new approach goes far beyond isolated neural network executions, bringing together multi-sensor fusion, situational awareness, and local motion control.
    🚀 Cross-Architecture Integration and Local Robotic Control​
    The implementation of autonomous physical AI requires robust hardware layers to manage high-bandwidth data streams from multi-directional image sensors and internal vehicle positioning systems. At COMPUTEX 2026 in Taipei, heterogeneous chips from leading suppliers such as Intel, NVIDIA, MediaTek, NXP, AMD, and Qualcomm were integrated into unified computing platforms to stabilize real-world hardware actions.
    The general-purpose robot Moby, designed by Noble Machines, is a striking example of this integration. Moby utilizes a specialized deep learning accelerator platform called DLAP-711, which includes an integrated neural engine to manage full-body mechanical control loops and simultaneous localization and mapping (SLAM) workloads. This ensures deterministic latency for physical movement while successfully handling real-time machine vision tasks.
    💡 Industry-Specific Display Solutions and Accelerated Software-Based Motion Frameworks​
    Beyond autonomous mobile robots, the convergence of computing and specialized display systems addresses the precise visualization requirements in complex clinical and commercial environments. Medical computing motherboards and MXM graphics modules are paired with advanced industrial display panels developed by AUO Display Plus, allowing operators to create three-dimensional viewing structures with the naked eye. These independent visualization systems provide the local, real-time spatial processing necessary for high-precision diagnostic operations and next-generation medical imaging analysis, without the need for secondary cloud connections.
    The computing framework for automated manufacturing and logistics systems has been adapted to optimize both high-power tracking and power-constrained terminal operations:
    • []Intelligent Interactive Display Systems: Double-sided transparent micro-LED displays are controlled by the MXA-312M dual-display computing chassis. This device uses MediaTek Genio application processors to perform continuous natural language translation and real-time contextual analysis in commercial retail environments.
      ]Software-Based Automation Platforms: Industrial computer controllers run programmable software-based motion logic, enabling machine builders to validate complex physical mechanics and implement automated workflows through digital twin simulations prior to physical deployment in the field.
    • Agent-Based Edge Automation: Compact computer-on-modules, designed around energy-efficient micro-architectures, run local autonomous agents. These modules execute localized task commands in micro-robotic arms, ensuring full data privacy and operational continuity even when network connectivity is lost.
    ⚙️ Enterprise Hardware Line Optimization for Intelligent Infrastructure​
    Scaling edge AI from isolated devices to comprehensive industrial networks requires localized edge servers capable of executing larger and more complex model parameters. Thanks to the newly introduced AXE series edge servers, enterprise facilities can implement localized factory execution layers. These high-performance graphics-accelerated servers optimize facility scheduling by analyzing ongoing operational data and provide real-time decision support directly on the factory floor. This achievement has also been recognized with industry accolades such as the Gartner Innovation Award.
    To ensure long-term stability in these diverse operational areas, computing platforms designed to withstand harsh conditions provide autonomous decision-making capabilities to unmanned vehicles navigating unstructured outdoor environments. These robust enclosures isolate sensitive semiconductor components from extreme thermal and mechanical shocks, ensuring reliable sensing lines across variable field terrains. This comprehensive deployment framework helps operators bridge the technical gap between abstract machine learning research and stable, long-lasting industrial application.
    🔬 Technical Deep Dive: The Superiority of DLAP-711​
    Industrial edge computing platforms are evaluated using different performance criteria, focusing on mathematical processing densities, interface bandwidth constraints, and thermal operating envelopes. Standard industrial box PCs using previous-generation embedded modules often experience input-output bottlenecks when processing simultaneous high-speed camera feeds, often limiting multi-camera vision networks to legacy PCI Express Gen 3 limits.
    The DLAP-711 system changes this benchmark with an advanced system-on-chip (SoC) integration that combines a 14-core ARM Neoverse-V3AE processor with a custom Blackwell architecture graphics processing unit. This configuration delivers 2,070 trillion floating-point operations per second (TFLOPS) using optimized four-bit sparse computations (FP4 TFLOPS). To process the high-density data required for full spatial awareness, the platform integrates up to eight dedicated Gigabit Multimedia Serial Link Gen 2 camera interfaces with a high-bandwidth QSFP28 network port supporting up to four 25-Gigabit Ethernet channels.
    Unlike competing modular form factor carriers such as Advantech or IEI Integration Corp, which often separate high-speed image capture from the main processing board, the unified DLAP-711 architecture provides direct, low-latency access to 128 Gigabytes of unified LPDDR5X system memory. Furthermore, while standard commercial hardware prototypes experience performance degradation at high temperatures, this industrial chassis maintains full mathematical execution within a verified temperature range of -20 degrees Celsius to 65 degrees Celsius, forming an integrated hardware foundation for demanding field deployments.
