Product Review: Actuators and Cylinders (May 2026) π
We have compiled the latest innovations in actuator and cylinder technologies, which are at the heart of industrial automation, for you. This month's review features groundbreaking solutions for engineers seeking precision, power, and efficiency.
βββββββββββββββββββββββββ
π§ Thomson Precision Linear Actuators: Where Power Meets Compactness
The Thomson PC Series combines high power density with a compact design. These actuators are ideal for applications requiring precision, repeatability, and long life. The large-diameter ball screw ensures consistent positioning while extending service life. Offering load capacities up to 6000 N and speeds exceeding 1 m/s, this series features a precision ball nut and anti-rotation design, providing quiet and smooth operation while managing lateral loads.
[]Configurations: Inline and parallel options.
[]Protection: IP65 rated, sealed design.
[]Motor Integration: Comes fully compatible and tested with Kollmorgen's AKM servo motors, a Regal Rexnord brand.
[]Flexibility: With the optional RediMount kit, over 600 motor types can be easily mounted.
β‘ Festo Electric Cylinder: Compact and Fast Solutions
The Festo EPCC, with its compact dimensions and precise, quiet ball screw drive, is suitable for use in assembly systems, test and inspection systems, desktop applications, and small parts handling. It stands out with its fast positioning time.
[]Features: Low internal friction, anti-rotation capabilities, and a piston rod with slide guide up to 500 mm stroke.
[]Mounting: Various mounting options available for the motor.
[]Space Efficiency: The "one size smaller" mounting system, combined with the ELGC toothed belt/spindle axis, ensures optimal space utilization.
βοΈ AutomationDirect Stepper Motor Linear Actuators: Economical and Durable
SureStep linear actuators are NEMA 17 or NEMA 23 frame stepper motors with a stainless steel lead screw extension on the rotor. They are typically used with un-driven linear slides or linear shafts/supports to provide simple and economical linear motion solutions.
- ]Capacity: Thrust force up to 193 lbs.
[]Speed: Speeds up to 18 in/sec.
[]Movement Per Step: 0.25 in/rev, 0.5 in/rev, or 1.0 in/rev options.
[]Long Life: High durability and long service life.
[]Sizes: 6-inch, 9-inch, and 12-inch standard lengths.
[]Design Options: Trunnion mount and retaining ring groove (at screw end) or rear motor shaft and encoder mounting hole styles.
[]Shape: Triangular design for narrow spaces, optional round design also available.
π‘ Tolomatic Linear Servo Actuators: Integrated Solutions
The IMA linear servo actuator, by incorporating an integrated servo motor, simplifies mechanical designs. It is a compact, industrial package designed to replace hydraulic systems, operate in tight spaces, or for applications exposed to high shock and vibration.
[]Flexibility: Ideal for hydraulic replacement, tight spaces, or high shock/vibration conditions.
[]Sizes: Four different body sizes.
[]Stroke Lengths: Stroke lengths up to 18 inches and custom order options.
[]Force: Forces up to 8,000 lbf.
[]Screw Options: Ball and roller screw options.
[]Protection: IP67 option for protection against dust and water ingress.
π Bosch Rexroth Electromechanical Cylinder: Designed for Heavy Loads
The Bosch Rexroth EMC-HP (high power) electromechanical cylinder was specifically developed for heavy-duty applications. Thanks to its compact design and IP54 sealing, it ensures high continuous performance even in harsh conditions.
[]Performance: Optional water cooling and maintenance-friendly lubrication guarantee reliable operation.
[]Precision: The high-precision planetary screw assembly enables precise positioning of loads weighing tons.
[]Flexibility: The flexibility of the EMC-HP allows users to change parameters and create complex motion profiles.
[]New Sizes: With the new 190 and 220 sizes, applications requiring forces up to 250 kN can be realized even in confined spaces.
[*]Data and Analysis: The integrated sensor package provides critical information to maximize efficiency and service life.
The actuator and cylinder solutions featured in this month's product review offer significant advantages for businesses seeking efficiency, precision, and durability in industrial automation. Each product stands out with its specific capabilities tailored to different application needs.
