πŸ€– Expanding Expert Decision-Making Capacity with AI Reasoning Agents πŸš€
Ahmet Γ–.
    Over the last decade, energy and heavy industrial companies have invested heavily in digital transformation. While process historians record millions of data points, maintenance systems track decades of work history, and engineering knowledge is locked away in documents, drawings, and reports, efficiency gains have remained surprisingly modest.
    πŸ’‘ From Data Abundance to Decision Scarcity​
    The problem is no longer visibility; it’s the speed of decision-making. There is no shortage of data or insights across operations, maintenance, and reliability. What is limited is the ability to consistently interpret this information and translate it into the right action at the right time.
    Engineers are asked daily to answer questions that require synthesizing multiple domains:
    • []Is this vibration issue mechanical, or is it caused by upstream process conditions?
      ]Should the equipment be shut down now, or can it run until the next outage?
    • Are current conditions within a safe operating envelope, or are minor deviations escalating into a larger risk?
    These are not simple questions. They require context, experience, and judgment. In most facilities, this capability resides with a small number of experienced engineers. They pull data from multiple systems and manually piece together conclusions. This work is time-consuming and difficult to scale, leading to many decisions being delayed or not made at all. As assets age and experienced personnel retire, this constraint becomes even more pronounced. The problem is more about scaling expertise.
    🧠 AI Reasoning Agents: Moving from Detection to Decision​
    AI reasoning agents are emerging to fill this gap. Unlike previous systems that focused on detecting anomalies, these technologies are designed to emulate how experienced engineers diagnose problems and make decisions. By synthesizing time-series data, maintenance history, and engineering context, they apply domain-specific reasoning to link symptoms to probable causes and recommended actions.
    Rather than just flagging a deviation, the system generates a structured explanation outlining what happened, why it happened, how confident the conclusion is, and what actions should be considered. This shift from detection to decision support enables organizations to act more consistently and with greater confidence.
    βš™οΈ Use Case 1: Root Cause Analysis in Rotating Equipment​
    A common example can be found in rotating equipment. Consider a centrifugal pump whose vibration begins to increase after a maintenance event. A traditional system would flag the anomaly, then an engineer would investigate: reviewing trends, checking maintenance history, and consulting documentation. Depending on the complexity, this process could take hours or even days.
    A reasoning agent specialized in root cause diagnosis and remediation compresses this workflow. It can automatically correlate the vibration increase with a recent coupling disassembly, evaluate patterns consistent with different failure modes, and surface similar historical cases on analogous equipment. When it classifies the event as misalignment rather than other failure modes, it recommends laser alignment with hot thermal growth targets, soft foot checks, and a revision to PM procedures, drawing on historical data and experience.
    While the agent provides earlier detection than legacy systems, much of the value came from a faster and more consistent diagnosis. Facilities using this approach reduce the time to resolution and prevent recurring failures by addressing underlying causes rather than reacting to symptoms.
    πŸ› οΈ Use Case 2: Maintenance Optimization in Practice​
    While root cause analysis addresses individual events, maintenance strategy presents a broader challenge. Many organizations still rely on time-based preventive maintenance, where equipment is serviced at fixed intervals regardless of its condition. Over time, this leads to unnecessary work on healthy assets and missed failures on assets that degrade between intervals.
    A maintenance optimization agent offers a continuous feedback loop. It analyzes historical work orders, failure events, and operating conditions to determine how maintenance frequency impacts reliability for each asset. Rather than applying a uniform strategy to a class of assets, it evaluates equipment based on its actual operating history.
    For example, a facility might perform quarterly maintenance on pumps but continue to experience recurring failures. The system can quantify the relationship between maintenance intervals and failure rates, helping to determine if the problem is insufficient maintenance or, in some cases, over-maintenance that introduces risk.
    Each recommendation is backed by a clear cost and risk trade-off, outlining the expected changes, such as failure frequency, maintenance cost, and potential production impact. Engineers can test scenarios, apply constraints, and review assumptions before implementing changes. Over time, this transforms maintenance strategy from a static, experience-based practice to a dynamic, evidence-based process, enabling teams to continuously focus their efforts on areas of greatest impact.
    🚨 Use Case 3: HAZOP as a Continuous Capability​
    Process hazard analysis (PHA) is a critical, regulatory activity to maximize process safety performance, but it has traditionally been static. The most common format of PHA, Hazard and Operability (HAZOP) studies, are conducted in five-year cycles, and the results are captured in documents that are difficult to access and rarely used in daily operations.
    A reasoning agent for HAZOP efficiency changes both the speed and frequency of this work. By ingesting P&IDs and engineering documents, the system builds a connected model of the process and generates a structured HAZOP outline, including nodes, deviations, causes, consequences, and safeguards. Preparations that once took weeks or months can now be generated in days, allowing engineers to focus on analysis rather than information gathering.
    More importantly, the analysis becomes more consistent. Rather than relying on what a team can recall in a workshop, agents can systematically evaluate deviation scenarios across the entire process, including interactions spanning multiple units. Engineers still review and refine the output, but they start from a well-structured and evidence-based starting point.
    The result is a more consistent, more accurate approach to process safety. Rather than waiting for the next revalidation cycle, teams can revisit full HAZOP analyses when operating conditions change or equipment is modified, minimizing gaps between design assumptions and actual operation.
    πŸ“ˆ Measurable Impact and the Way Forward​
    Early adopters across oil and gas, chemicals, and power generation are seeing a positive impact on operations with the implementation of AI reasoning agents. These include earlier detection and diagnoses, enabling planned mitigations at the source of process or equipment issues, reduced maintenance costs through better targeting of work, and improved asset performance.
    In many cases, teams are also seeing gains in energy efficiency.
