High-Performance Edge Computing Solution DX-1300 for Confined Spaces
Elif Özaksu
  • Altanlar
    Cincoze has introduced the DX-1300, a compact industrial computer powered by Intel Core Ultra processors. This system offers 36 TOPS of AI performance and is ideal for tight workspaces due to its rugged design.
    ### DX-1300 Technical Specifications
    • Dimensions: 242 mm × 173 mm × 75 mm
    • Utilizes Intel Core Ultra 200S processor
    • AI performance: 36 TOPS
    • Operating temperature range: -40°C to 60°C
    • Wide voltage range: 9 VDC - 48 VDC
    • Fanless and small mechanical part-free rugged design
    • Up to 96 GB DDR5 CSODIMM memory (up to 6400 MHz)
    • Storage supporting PCIe NVMe SSD and SATA
    • Supports 12 LAN ports or 8 PoE ports
    • M.2 slots for Wi-Fi, 5G, GNSS module support
    • MIL-STD-810H (shock and vibration), UL, EN 50121-3-2 (rail EMK), EN 45545-2 (fire safety) certifications
    The DX-1300 is designed for edge computing applications requiring high processing power in confined spaces. Utilizing Intel's Arrow Lake-S Core Ultra 200S platform, the system delivers high performance for various industrial applications, from real-time video analysis to automated inspection, without compromising performance.
    Offering flexible expansion options to users, the DX-1300 features M.2 slots for adding wireless modules such as Wi-Fi, 5G, or GNSS. Additionally, it supports multi-camera imaging systems with 12 LAN or 8 PoE ports. High-resolution and real-time analysis are made possible with Ethernet 10 GbE, 2.5 GbE, 1 GbE options, and USB 3.2 ports.
    ### Industrial Durability
    The DX-1300 enhances durability with its fanless design, making it resistant to dusty and vibrating environments, and its lack of moving parts. Its wide operating temperature range and voltage support ensure seamless operation in harsh conditions.
    ### Application Areas
    With certifications for passenger trains, factory automation, and early warning systems, the system is suitable for AI-based edge computing applications in industrial fields. Its fanless design offers quiet operation and low maintenance.
    The Cincoze DX-1300 is a special option for industrial users who need high-performance edge computing in confined spaces.
