IDEC has introduced the GT8A series of slim electronic timers, which save space in control panels and offer a wide range of functions. The new models expand the existing timer series, providing fast and compact solutions ideal for new, retrofit, and replacement applications.
### GT8A Slim Electronic Timer Features
- Width of only 17.5 mm, allowing direct DIN rail mounting, no socket required
- Saves space in control panels and reduces installation time
- 10 different timing functions: ON-delay, ON-delay with instantaneous contact, flicker (OFF start or ON start), OFF-delay, one-shot, interval, ON/OFF-delay, cyclic, and pulse modes
- 10 time ranges and 10 time settings, including permanent ON or OFF, provide timing from 0.1 seconds to 10 days
- Easy configuration with three recessed rotary switches to prevent accidental changes
- Single-contact SPDT and double-contact DPDT models
- Contact load capacity: 250V AC or 24V DC, 16A resistive load
- Universal control supply: 12-240V AC/DC
### Reliability and Compliance
- Minimum 30 million mechanical operations
- Minimum 50,000 electrical operations at full load
- 600 operating cycles per hour
- Finger-safe IP20 (IEC 60529) protection
- EN 61812-1, CE, UKCA, RoHS, EAC, UL/c-UL certifications
### Applications and Advantages
Timers provide critical hardwired control functions for pump stations, HVAC systems, material handling, building automation, and machine and equipment control. The compact design of the GT8A offers high performance and ease of use compared to analog and electro-mechanical alternatives.
The IDEC GT8A series, as part of a rich product portfolio, offers various design options. Furthermore, IDEC provides free technical support for the GT8A, as with all its products, without the need for a service or support contract.
### About IDEC
Since 1945, IDEC Corporation has been offering innovative and reliable industrial automation and control products, with a wide range including PLCs, HMIs, safety products, and automation components. With the acquisitions of APEM and ez-Wheel, product quality and customer solutions are continuously being developed.
