Diğer Functional Safety Encoder for Reliable Positioning from Dunkermotoren
    Dunkermotoren has introduced a new functional safety encoder called AFS58. This absolute encoder is designed to provide high-precision and reliable position feedback in demanding industrial motion systems. With a 2048 pulses/revolution Sin/Cos signal and SIL2 and Performance Level d approval, this device offers a robust structure that is ready for immediate use after installation.
    ### AFS58 Functional Safety Encoder Features
    • High-resolution position feedback with 2048 pulses per revolution Sin/Cos output
    • SIL2 and Performance Level d compliance
    • Maximum operating speed of 6000 rpm
    • Standard electrical interface with 5 V supply voltage
    • Easy and consistent wiring with M12 connectors
    • Compact design in a standard 58 mm encoder size
    • Fully compatible with Dunkermotoren BG66, BG75, and BG95 motor series
    The AFS58 is suitable for both position tracking and safe stop functions in applications where motion is monitored and controlled, such as CNC machining and robotics. Thanks to the high signal quality in closed-loop control systems, position, speed, and direction can be detected more precisely.
    M12 connection connectors are used for user convenience, and seamless integration into existing motor and feedback systems can be achieved due to the standard 58 mm housing size. The AFS58 is designed for continuous industrial use and offers additional application-specific protection options if needed.
    In summary, the Dunkermotoren AFS58 encoder offers a combination of high-resolution Sin/Cos signal, functional safety certifications, and compatibility with BG motor series, making it an ideal solution for systems requiring precise and safe position feedback.
