Igus has introduced drylin C, its innovative oil-free bearing guide developed for quiet, smooth, and maintenance-free motion. This system is specifically designed for applications requiring low operating forces and silent operation, offering solutions to accessibility and comfort demands across a wide range of fields, from mechanical engineering to public infrastructure.
### drylin C Design and Features
- Three-bearing system: Two fixed and one adjustable high-performance plastic roller eliminate play, making movement precise and consistent.
- Low coefficient of friction is achieved thanks to ball bearings and optimized color diameters.
- Loads of up to 20 kg per carriage can be moved with minimal force.
- Operates completely oil-free without using metal components, eliminating the need for maintenance and making it suitable for hygienic environments.
- The combination of plastic bearings and aluminum profiles offers long life, corrosion resistance, and reliable performance.
- Lightweight, anodized aluminum profiles and durable die-cast zinc carriages create a compact and economical solution.
### Installation and Application Flexibility
- The ability to create curved profiles starting from a 500 mm radius makes it ideal for limited spaces and complex designs.
- Facilitates integration with optional accessories such as end stops, mounting brackets, and scrapers.
- Typical applications include sliding doors, covers, self-service systems, curved doors on trains, marine applications, and display/machine guard positioning systems.
### Efficiency and User Comfort
- Low friction and silent operation capabilities enhance energy efficiency and user comfort.
- Enables high performance with less powerful drive systems.
Igus drylin C expands its automation portfolio as a durable, flexible, and maintenance-free solution that combines mechanical efficiency with modern accessibility and comfort requirements.
