Multi-Protocol Support in Industrial Devices with RTConnect Embedded Protocol Module
    The RTConnect 6-in-1 module enhances universal system compatibility by adding EtherNet/IP, PROFINET, OPC UA, BACnet/IP, Modbus TCP, and MQTT protocols to your devices. This embedded module simplifies the integration process and reduces developer burden by equipping serial devices with Ethernet-based multi-industrial protocols.
    ### RTConnect 6-in-1 Protocol Module Features
    • Support for EtherNet/IP, PROFINET, OPC UA, BACnet/IP, Modbus TCP, and MQTT with a single compact serial-to-Ethernet interface
    • Accelerate time-to-market by adding Ethernet to your serial devices with a simple PCB change
    • Increase product profitability with a low-cost module instead of expensive internal developments
    • Send data to the cloud by adding wireless communication and bridge the gap between factory and office performance
    • Minimize development risk by using market-proven hardware and software that passes annual successful certifications
    • Support from an expert with 30+ years of experience, from design phase to launch
    ### Easy Access to Every Automation Market with Multiple Protocols
    By integrating the RAConnect module into your existing hardware design, you can make your device compatible with systems from major PLC manufacturers like Allen-Bradley, Siemens, and Schneider Electric. Additionally, your product will be recognizable in building automation systems. Since all protocol complexity resides within the module, you don't need to write a single line of protocol code.
    ### Integration Process
    1. Integrate the RTConnect module into your hardware design.
    2. Power the module with 3.3V DC and connect your existing serial UART line.
    3. Map your serial data to the desired Ethernet protocols by following RTA's development process.
    ### Support Provided by RTA
    • Hardware design documentation and protocol information gathering
    • Modeling and documentation of device data according to protocols
    • Internal tests for data integrity and industrial security
    • Testing and certification support for protocols requiring certification
    • Training of internal teams and review of technical documentation
    • Protocol maintenance and meeting production requirements
    The RTConnect module offers a comprehensive protocol package to device developers, making your products ready for global automation markets and providing high-performance, compatible solutions.
