High-Capacity and Easily Integrated MELFA RH-20CRH SCARA Robot
    The MELFA RH-20CRH is a high-speed, durable, and easily integrated SCARA robot with a 20 kg payload capacity. Its battery-less design and flexible control options make it suitable for modern automation needs.
    ### MELFA RH-20CRH SCARA Robot
    This robot offers high performance with a maximum payload capacity of 20 kg and a reach of 1000 mm. Its lightweight and compact structure reduces installation time, minimizes maintenance requirements, and lowers the total cost of ownership.
    ### Application Areas
    The RH-20CRH is used in areas such as material handling, packaging, assembly, and precise transfer. It is ideal for industries facing labor shortages and increasing production demands. Its small footprint design allows for easy integration into space-constrained cells.
    ### Key Features and Advantages
    Control Flexibility:
    • Supports common industrial communication protocols such as Ethernet/IP, PROFINET, Modbus, and EtherCAT
    • Ensures seamless integration in multi-vendor environments and existing automation structures
    Ease of Use and Integration:
    • Integrated cabling and pneumatic piping in the robot arm reduce external cable clutter and installation time
    • 32 digital inputs/32 digital outputs reduce the need for additional hardware
    • Battery-less motor design prevents position loss after power-off and reduces maintenance needs
    Performance and Durability:
    • Maximum 20 kg payload capacity
    • 1000 mm arm reach
    • 0.37 second cycle time
    • Stable and precise operation even at high speeds thanks to its durable and lightweight mechanical structure
    Warranty and Support:
    • Standard 3-year warranty
    • Warranty extendable up to 5 years with the Robot Diamond Assurance plan
    Backed by Mitsubishi Electric's commitment to long-term reliability, the RH-20CRH is a powerful solution for those seeking efficiency and durability in their production processes.
