Weidmuller's PROeco II Power Supply Series Offering Fast Connection and High Efficiency
    Weidmuller has introduced its PROeco II power supply series with Snap In technology. This new series has been developed to accelerate the installation process and simplify industrial panel mounting. With tool-free connection, up to 95% efficiency, and a compact design, it offers solutions that provide space savings and reliability in automation, machine manufacturing, and energy applications.
    ### Easy Installation with Snap In Technology
    The Snap In system offers quick and practical connection without the need for tools. This significantly reduces wiring time during panel assembly and field installation. Thanks to automatic wiring support, it is also suitable for robotic panel production. During maintenance, it provides easy quick connection and disconnection, speeding up fault detection and minimizing downtime.
    ### PROeco II Features
    • With a slim profile of approximately 100 mm, it easily fits into compact control panels.
    • High energy efficiency of up to 95% reduces energy losses and heat generation.
    • Ensures reliable operation across a wide temperature range, starting from -40°C.
    • Mean Time Between Failures (MTBF) is over 1 million hours.
    • A three-color LED display clearly shows operating status, overload, and error notifications.
    • Can be connected to real-time monitoring and warning systems with its built-in status relay.
    • Works compatibly with modular power systems, providing flexible power management.
    • Supports energy savings in continuously operating systems with low idle power consumption.
    ### Application Areas
    PROeco II can be preferred in many industrial areas such as automation, robotics, OEM machine manufacturing, building management, material handling, and energy infrastructure. With its fast assembly and high reliability, it increases installation efficiency and system performance in the long run.
    Weidmuller PROeco II offers a strong alternative for users seeking practicality and high operational quality, balancing performance with easy integration and maintenance requirements.
