Weidmuller has introduced the PROeco II power supply series with Snap In technology, aiming to accelerate industrial panel mounting and simplify wiring. With tool-free connection, up to 95% efficiency, and a compact design, it offers an ideal solution for projects where space and reliability are priorities, especially in automation, machine manufacturing, and energy applications.
### PROeco II Snap In Power Supply Features
- Fast and easy installation with tool-free Snap In connection system
- Slim design of approximately 100 mm, compatible with compact control panels
- Up to 95% energy efficiency for low energy loss
- Wide operating temperature range, reliable operation starting from -40°C
- Long service life with an MTBF value of over 1 million hours
- Integrated three-color LED display for operating status, overload, and fault indication
- Built-in status relay for real-time monitoring and alerts
- Compatible with modular power systems, can integrate with DC UPS, load monitoring, and diode modules
The Snap In system eliminates the need for tools in wiring, saving time in both panel mounting and field installations. This feature simplifies the process in systems with numerous connections and is also suitable for automated wiring. The ability to quickly connect and disconnect during maintenance shortens fault detection times and reduces downtime.
PROeco II power supplies, with their slim profile structure that can be easily placed in compact panels, are compatible with modern distributed panel designs. Low idle power consumption increases energy efficiency, especially in systems that operate continuously and under variable loads.
High efficiency reduces energy loss, which in turn limits the heat generated in the control panel. This eliminates the need for additional cooling, keeping the system stable while reducing costs.
Designed for industrial applications, this series can operate in a wide temperature range and reliably start up even at -40°C. With its long-lasting structure, it meets the need for an uninterrupted power supply in harsh conditions.
The PROeco II's integrated three-color LED display clearly shows status, overload, and fault information without the need for additional diagnostic tools. The built-in status relay connects to control systems, enabling real-time monitoring and alerts, thereby speeding up maintenance and fault detection.
The series can be integrated into modular power management systems; it works compatibly with DC UPS units, load monitoring, and diode modules, providing flexible and scalable solutions in the system.
This new PROeco II power supply series can be preferred in a wide range of industrial applications such as automation, robotics, OEM machine manufacturing, building management, material handling, and energy infrastructure. With its fast wiring, compact structure, and reliable performance, it both simplifies the installation process and supports long-term system stability.
Offering performance, ease of integration, and maintenance advantages all in one, the PROeco II Snap In series stands out as a reliable and practical power supply solution for industry users.
