Add Industrial Protocols to Your Devices with the RTConnect 6-in-1 Protocol Module
    The RTConnect 6-in-1 protocol module provides access to global automation markets by adding EtherNet/IP, PROFINET, OPC UA, BACnet/IP, Modbus TCP, and MQTT protocols to your serial devices. This embedded module empowers your serial devices with universal system compatibility and significantly simplifies the integration process.
    ### Advantages of the RTConnect Module
    • Add multiple industrial protocols with a single, compact serial-to-Ethernet interface.
    • Quickly integrate Ethernet support with a simple modification to your existing PCB design.
    • Maximize product profitability by replacing expensive in-house development processes with low-cost modules.
    • Add wireless communication to send data to the cloud, connecting factory and office performance.
    • Reduce development risk with hardware and software proven in successful certifications every year.
    • Receive expert support and consulting services with over 30 years of experience.
    ### Open Up to Automation Markets with Multi-Protocol Flexibility
    The RTConnect module enables your devices to communicate compatibly with Allen-Bradley, Siemens, and Schneider Electric PLCs. It also allows your device to be discovered in building automation systems. All protocol management is embedded within the module, eliminating the need for you to write code.
    RTA's expert engineers simplify the process with data modeling, certification support, and go-to-market training. They also handle protocol maintenance and updates without user intervention, ensuring your device remains competitive and compliant with standards.
    ### How It Works?
    1. Integrate the RTConnect module into your PCB design.
    2. Provide 3.3V DC power to the module and connect your existing serial UART line.
    3. Follow RTA's development process to configure your serial data according to the supported protocols.
    ### RTConnect Module Technical Specifications
    • Protocols: EtherNet/IP, PROFINET, OPC UA, BACnet/IP, Modbus TCP, MQTT
    • Power: 3.3V DC
    • Interface: Serial UART to Ethernet adaptation
    • Application: Industrial automation and building automation integrations
    • Support: Design documentation, data modeling, certification support, training, and protocol maintenance
    With the RTConnect 6-in-1 protocol module, you can save development time and costs while making your devices compatible with global automation standards.
