Weidmuller's Fast-Mount Compact PROeco II Power Supplies
    Weidmuller has introduced its PROeco II power supply series with Snap In technology, aiming to simplify industrial panel mounting and reduce wiring times. With tool-free connections, up to 95% efficiency, and a compact design, it offers a suitable solution for automation, machine manufacturing, and energy applications.
    ### PROeco II Snap In Technology
    The Snap In system is designed for quick and practical assembly. Tool-free connections save time during panel mounting and on-site installation. It shortens the wiring process, especially in systems with numerous connections, and provides automatic wiring support for robotic panel production. It reduces troubleshooting time by allowing quick connection and disconnection during maintenance.
    ### Compact and Efficient Design
    Thanks to its slim profile, approximately 100 mm wide, PROeco II power supplies fit easily into compact control panels and are compatible with modern distributed panel designs. Its low idle power consumption increases energy efficiency, especially in systems operating continuously under variable loads.
    The series minimizes heat generation by reducing energy losses with an efficiency rate of up to 95%. This reduces the need for additional cooling, making the system more stable and economical.
    ### PROeco II Technical Specifications
    • Starting operating temperature: -40°C
    • Wide operating temperature range
    • Mean Time Between Failures (MTBF): Over 1 million hours
    • Operating status, overload, and error indication with a three-color LED display
    • Real-time monitoring and alarm support with an integrated status relay
    • Modular power systems compatible with DC UPS, load monitoring, and diode modules
    ### Durability and Flexibility
    Designed for harsh industrial environments, PROeco II offers long-lasting and durable connections. Its reliable operation across a wide temperature range and low maintenance requirements make it an ideal solution for energy infrastructure, automation, and robotic applications.
    ### Application Areas
    • Automation
    • Robotics
    • OEM machine manufacturing
    • Building management systems
    • Material handling
    • Energy infrastructure
    PROeco II enhances efficiency in both installation and long-term operations with its quick assembly and reliable structure. By combining performance with easy integration and service features, it stands out as an attractive power supply option for industrial users.
