⚡ Smart Motor Starting Technology with SIMATIC ET 200SP e-Starter
    In motor starting applications, speed, protection, and flexibility are more important than ever.
    👉Responds up to 1,000 times faster thanks to its fully electronic and wear-free switching structure.
    👉Resettable internal short-circuit protection eliminates the need for device replacement after a fault.
    👉Innovative Smart-Start technology neutralizes starting currents, reduces torque shocks, and protects motors more precisely.
    👉With TIA Portal integration, parameterization, diagnostics, and commissioning processes are easily managed from a single platform.
    Faster response, less downtime, and higher system reliability.
    🚀 Why e-Starter?​
    ⚡ 1️⃣ Up to 1,000 Times Faster Response​
    Thanks to the fully electronic switching structure, there is no mechanical delay.
    This means:
    • Faster cut-off time
    • Higher safety in critical loads
    • Stable operation in sensitive processes
    means.
    🔄 2️⃣ Resettable Internal Short-Circuit Protection​
    Device replacement after a short circuit? No longer necessary.
    Thanks to e-Starter's integrated and resettable protection system:
    • Maintenance costs are reduced
    • Spare parts requirement decreases
    • Unplanned downtime is minimized
    This provides a significant advantage, especially for OEM machine manufacturers.
    🧠 3️⃣ Controlled Start with Smart-Start Technology​
    Sudden starting currents shorten motor life.
    Smart-Start technology:
    • Neutralizes starting current
    • Reduces torque shocks
    • Minimizes mechanical stress
    • Extends motor life
    Makes a big difference in conveyor systems, pump applications, and sensitive loads.
    🖥 4️⃣ TIA Portal Integration​
    Thanks to TIA Portal integration:
    • Parameterization
    • Online diagnostics
    • Fast commissioning
    • Centralized monitoring
    are managed from a single platform.
    This shortens engineering time and reduces the risk of errors.
    🏭 In Which Applications Does It Excel?​
    • Conveyor and transport systems
    • Packaging machines
    • Pump & fan applications
    • Automotive production lines
    • Modular machine systems
    📈 Added Value for the Enterprise​
    ✔ Faster fault intervention
    ✔ Less unplanned downtime
    ✔ Longer motor life
    ✔ Lower maintenance costs
    ✔ Higher system reliability
