🚀 High-Performance Safety Locks and Control Stations: A New Era in Industrial Automation! 🚀
SĂĽeda Asil
    ⚙️ IDEM Safety Switches' DS Series: Robustness and Efficiency Combined ⚙️​
    IDEM Safety Switches has introduced its new DS Series, designed for industrial automation and advanced manufacturing environments. These heavy-duty, configurable pushbutton control units and integrated safety interlocks have been developed to optimize operator control and machine safety.
    đź’Ş Durable Design for Harsh Conditions đź’Ş​
    The DS Series features a heavy-duty die-cast metal body, designed to withstand harsh operating conditions. This provides long-lasting structural durability and reliable performance. The unit's narrow 40mm profile allows for direct mounting onto industrial guarding frames. This compact structure saves installation space while maintaining structural integrity in high-vibration and demanding environments.
    ⚡ Plug-and-Play Connectivity and Rapid Commissioning ⚡​
    To minimize wiring errors and reduce installation effort, each control station utilizes a pre-configured quick-connect interface. The units arrive fully assembled and pre-wired from the factory. This ensures standardized build quality and accelerates commissioning. By eliminating manual wiring steps on-site, it reduces overall commissioning costs in complex automation lines.
    🎨 Modular Pilot Device Layouts and Visual Identification 🎨​
    The architecture supports up to 10 integrated pilot devices as standard, including emergency stop buttons and standard pushbuttons. Each assembly includes a colored lens pack and an ISO-compliant symbol label pack. These components provide clear and standardized identification of control functions, allowing operators to quickly distinguish individual inputs and execute commands without ambiguity.
    đź”’ Functional Safety Integration and RFID Interlocking đź”’​
    For applications requiring physical access control, the DS Series can be specified with the optional DS-MLZ Type 4 monitored interlock, featuring a high-coded RFID actuator. This configuration provides a maximum holding force of up to 4,000 N for hinged and sliding safety guards, along with tamper-resistant guard detection. Continuous monitoring of both guard position and lock status facilitates seamless integration into safety-related control systems up to Category 4, PL e, and SIL 3.
    📊 Technical Details and Competitive Advantages 📊​
    The DS Series offers standard part numbers for configurations containing two to five devices, while configurations with six to 10 devices utilize a digital product configurator. Compared to traditional modular control stations, the DS Series' integrated die-cast approach reduces the mechanical footprint by housing control and interlocking elements within a single 40mm profile. The inclusion of Type 4 high-coded RFID interlocking meets ISO 14119 requirements, minimizing defeat possibilities and matching or exceeding the diagnostic coverage provided by standard magnetic or low-coded safety switches.
    IDEM DS Series: Safety & Control in One
    The new DS Series combines heavy-duty pushbutton control, RFID safety interlocking and plug-and-play connectivity in a compact 40 mm design—built for demanding industrial automation environments.
    Spad Electronic — supporting reliable machine safety and industrial automation solutions.
    www.spad1.ir |
