FAULHABER BXI: Powerful Integrated Drive System for the Next Generation in Robotics
    ## FAULHABER BXI: The Power of the Next Generation in Robotics
    FAULHABER has introduced BXI, a new integrated drive system developed to meet the high precision, power, and dynamic requirements of modern robotic applications. This system is ideal for the precision and coordination required for human-like movements.
    ### Power and Precision in Human-Like Movements
    The FAULHABER BXI 9317 series features an internal rotor motor that combines durability and a compact design. With a maximum torque of 20 Nm, it provides fast response times, dynamic movements, and highly precise control. This allows for both delicate gripping movements and powerful, coordinated joint movements to be performed with ease.
    The motor operates within a 50 V voltage range and has a mounting length of only 34 mm, facilitating integration into existing systems. These features make it particularly suitable as a compact joint drive in applications where every millimeter, gram, and high power density are critical, such as in humanoid robots.
    ### FAULHABER BXI Features
    • Maximum torque: 20 Nm
    • Voltage range: 0-50 V
    • Mounting length: 34 mm
    • Integrated stepped planetary gearbox
    • High-resolution absolute encoder (15-bit SSI)
    • 21 pole pair internal rotor design
    • Low cogging torque
    • Optimized heat dissipation and corrosion resistance with aluminum housing
    • Compact, durable, and high power density
    ### Superior System Compatibility and Control
    When combined with the FAULHABER MC5010 Motion Controller, it forms a complete and compatible system for applications requiring torque precision and high accuracy. The BXI can be quickly commissioned thanks to its reliable protection features and Motion Manager software.
    This technology offers a powerful platform for innovative, high-performance, and future-proof robotic solutions.
    FAULHABER BXI stands out as an ideal choice for industry professionals who want to provide high power in small sizes for modern robotic applications.
