In this thread, I will introduce you to n8n, an open-source, powerful, and flexible automation tool. If you've used tools like Zapier or Make.com but are looking for a more free and unlimited solution, n8n is perfect for you!
Its content should be as follows:
Install:
👉 Access from browser: http://localhost:5678
If anyone on the forum is using it, could you share your scenarios?
I can also share example JSON files if you'd like.
🧠 What is n8n?
- An open-source automation tool
- Can be self-hosted on your own server
- Unlimited workflows and integrations
- Visual interface for creating scenarios without coding knowledge
- Over 350 pre-built integrations (Slack, Telegram, Email, MySQL, Webhook, HTTP Request, etc.)
🛠️ Installation with Docker
Bash:
mkdir n8n
cd n8n
nano docker-compose.yml
YAML:
version: "3"
services:
n8n:
image: n8nio/n8n
ports:
- "5678:5678"
environment:
- N8N_BASIC_AUTH_ACTIVE=true
- N8N_BASIC_AUTH_USER=admin
- N8N_BASIC_AUTH_PASSWORD=123456
- TZ=Europe/Istanbul
volumes:
- ~/.n8n:/home/node/.n8n
Install:
YAML:
docker compose up -d
💡 What Can I Do?
- Send a notification to Telegram when a form is filled
- Get data from an API, write to CSV, and send via email
- Receive sensor data and save it to a database
- Create a Slack notification when an order arrives on your e-commerce site
🧪 Example: Flow to Send a Message to Telegram
- Webhook node → sends data from external system
- Set node → message format is defined
- Telegram node → message is sent
🌍 Resources
- 🔗 n8n.io (official site)
- 📘 n8n documentation
- 💬 Community forum
- 📦 GitHub
🎯 Over to You
