## KUKA's AI Platform for Scalable Industrial Automation
KUKA has developed a new software-based solution called the Automation Management Platform (AMP) to standardize AI-powered automation in robots, mobile systems, and production environments.
### A Solution Combining AI and Industrial Production Environments
Industrial robots are optimized for repeatability, but adapting to changing production conditions often requires manual reconfiguration, expertise, and fragmented toolchains. KUKA AMP aims to overcome these limitations by offering a structured framework for how AI systems interpret, decide, and act in real-world environments.
The platform standardizes data, actions, and semantics across different assets, ensuring consistent behavior in heterogeneous systems. This structure enhances the predictability, safety, and scalability of AI-powered automation in environments with high variability and dynamic conditions.
### KUKA AMP Features
- Provides a software-centric platform layer, bridging AI agents and physical hardware.
- The semantics component allows systems to understand intentions and convert real-world conditions into machine-readable structures.
- The actions component provides consistent control interfaces for robots, autonomous mobile robots (AMRs), and production equipment.
- The data component records operational states, enabling continuous optimization through feedback loops.
- Operations are continuously monitored, executed, evaluated, and improved through closed-loop systems.
### Digital Twin Integration and Continuous Optimization
KUKA AMP operates in a continuous cycle involving abstraction, monitoring, execution, and prediction by linking real-world operations with digital twins. This ensures that every task, process, and exception contributes to system learning, leading to performance improvements over time.
### Open API for Integrated Automation Ecosystems
The platform is developed with a modular and open API design that enables the integration of industrial robots, AMRs, work cells, software tools, and digital services into a single environment. This allows the entire lifecycle of design, simulation, commissioning, monitoring, and optimization to be managed through a single interface.
### Strategic Role in Next-Generation Automation
With over 550,000 robot installations worldwide and a strong presence in key markets like China, KUKA aims to advance the field of automation into new application areas with its AI-powered platforms. The Automation Management Platform plays a central role in the transition to flexible, intelligent, and connected industrial systems.
