What is a Load Break Switch?
Gooseyluke
Load break switches are critical switching elements used in high-voltage electrical power transmission and distribution systems to safely and controllably interrupt or re-establish current in a circuit. These devices enable the safe disconnection of power in situations such as overcurrent short circuits or maintenance requirements that may occur in electrical grids.
Load break switches do not only serve the function of opening and closing a circuit. They contribute to the safe operation of the power infrastructure by ensuring the stability, continuity, and reliability of the electrical system.
What is the Purpose of a Load Break Switch?​
Load break switches serve to transmit and distribute electrical energy safely, efficiently, and continuously. On the other hand, they safely control current in high-voltage circuits during fault conditions or planned maintenance processes.
They also similarly safeguard the physical security and operational status of energy systems. Therefore, the correct selection and maintenance of load break switches are crucial for increasing safety in energy transmission and distribution, extending system life, and minimizing potential faults.
What are the Operating Principles of Load Break Switches?​
Their operating principles are based on safely extinguishing arc formation at high current and voltage values. When the circuit is opened, the electrical arc formed between the conductors is eliminated by various methods depending on the technology used. In oil-immersed load break switches, special oil is used as the arc extinguishing medium, while in gas-insulated load break switches, SF₆ gas with high insulating properties is preferred.
In vacuum load break switches, the arc is extinguished quickly in a vacuum environment where air molecules are absent. In air-insulated load break switches, ambient air performs the insulation and cooling functions. These different types are selected based on the system's voltage level, frequency of use, maintenance conditions, and economic factors.
What is the Importance of Load Break Switches?​
The technical importance of load break switches stems not only from their ability to interrupt and connect power but also from their functions in ensuring system safety and personnel security. For fault clearance or maintenance work in high-voltage circuits, the circuit must be safely isolated.
