Teknoloji Muhabiri
Universal Robots introduced its new robot at Fabtech 2025. The UR8 Long, with its compact design and 1,750 mm reach, offers ideal solutions in areas such as welding and part placement.
Universal Robots' new robot, the UR8 Long, was introduced at Fabtech 2025. This robot, offering a 1,750 mm reach and an 8 kg payload capacity, provides advantages particularly in areas such as welding and bin picking. At the same time, with its high payload capacity of 10 kg and compact structure of 204 mm, it offers flexibility in factory environments. PolyScope 5 and PolyScope X software can be used for easy programming. With its light and convenient design, providing maneuverability in confined spaces, the UR8 Long continues to increase efficiency in the industry.
SEO keywords: Universal Robots UR8 Long, industrial robots, welding robot, bin picking robot, high reach robot, flexible industrial robot, fablab robots
Long-Range Robot Automation with UR8 Long
Universal Robots' UR8 Long model offers ideal solutions for controlling external axes and high-performance welding processes. This robot, thanks to MotionPlus technology, enables easy integration of linear and rotary axes; they move together, saving time and ensuring precision. It offers long-range and flexibility advantages, especially in welding and handling applications.
External Axis Control
Robots sometimes require axes that are outside the arm and manage another movement. The UR8 Long was designed to meet this need. It is used in applications such as welding rotating parts and allows the TCP and the external axis to move together with coordinated motion capability.
Advanced Features
The UR8 Long easily performs complex movements with MotionPlus technology. Thanks to its 8 kg payload capacity and compact structure, it performs with high efficiency even in confined spaces. It provides effective use in long continuous welds, cutting, and other automation processes without human intervention.
Conclusion
The UR8 Long robot meets the needs for long range and high precision, increasing efficiency in welding and automation applications. It offers fast programming and easy integration without the need for human intervention.
Related image: UR8 Long Welding Robot
Meta Description: Long-range automation solutions with the UR8 Long robot. Fast, precise, and superior performance with external axis control and MotionPlus technology. Ideal solution for welding and automation applications.
Advanced Features
Conclusion
