🛡️ Industrial Cybersecurity | Threats, Solutions, and Future in Critical Infrastructures
“SCADA system breached, production halted!”
This sentence is no longer just a cybersecurity exercise scenario — it's a real threat. As industrial facilities digitize, a new front has opened: the Cyber Battlefield.
💡 What is Industrial Cybersecurity?
Industrial cybersecurity is a discipline aimed at protecting the digital components of manufacturing, energy, transportation, and infrastructure systems against cyberattacks. These systems are generally referred to as OT (Operational Technology) and consist of control systems such as SCADA, PLC, HMI, and RTU.🔍 Why is it So Critical?
⚠️ Traditional IT Security is Insufficient for OT!
| IT Security | OT Security |
| Data-centric | Process-centric |
| Updates can be done regularly | Must operate continuously |
| Antivirus/Firewall common | Cannot be installed on some devices |
| Attack → data loss | Attack → explosion, death, production halt |
🎯 Threat Scenarios and Famous Attacks
🦠 STUXNET (2010)
Targeted Iranian nuclear facilities. PLCs were targeted, centrifuges were physically damaged.🔌 Ukraine Power Outage (2015)
SCADA systems were breached, leaving thousands of people in the dark.🏭 Triton (2017)
Attack on a petrochemical plant, targeting emergency safety systems. Physical explosion risk arose when the safety system was compromised.🧩 Why are OT Systems Vulnerable?
- Outdated systems that cannot be updated (Windows XP, 7 embedded systems)
- Insufficient network isolation (IT-OT convergence)
- Default passwords not changed (e.g., admin / 1234)
- Operators with low security awareness
- Physical threats introduced by USBs, laptops, and maintenance teams
🧰 Basic Measures to Take
1. Network Segmentation
- Physically separate OT networks from IT networks.
- Establish DMZ (Demilitarized Zone) layers.
2. Update and Patch Management
- Regular updates should be performed by backing up critical systems.
- Manufacturer-approved patches should be applied for SCADA/PLC systems.
3. Inventory and Monitoring
- A digital map of all devices and protocols should be created.
- Unusual traffic should be detected using SCADA monitoring tools.
4. Human Factor Training
- Operators should be trained against social engineering attacks.
- Awareness should be raised against suspicious USB and email habits.
5. Industrial Firewalls and IDPS
- Firewalls with protocol awareness (e.g., Modbus, DNP3) should be used.
- Systems that detect anomalies should be deployed.
🏭 Security Technologies Used in Industry
- Nozomi Networks, Claroty, Dragos → OT Monitoring and Threat Detection
- Siemens SCALANCE, Fortinet Rugged Firewall → Industrial Security Hardware
- OPC-UA Security, TLS Encryption → Secure protocol implementations
- Syslog / SIEM Integration → Log and monitoring systems
📚 IEC 62443: Industrial Cybersecurity Standard
- Similar to ISO/IEC 27001, it is a cybersecurity framework specific to OT systems.
- Covers all parties from asset owners to integrators.
- Main topics:
- Security levels
- Security lifecycle
- Risk assessment and mitigation
🌐 Situation in Turkey and the World
- Turkey: Energy, transportation, and defense industry companies, together with BTK and TSE, have started to increase infrastructure cybersecurity.
- World: Institutions such as NIST, CISA, and ENISA publish guidelines for industrial cybersecurity.
🤖 Industry 4.0 and IoT Threats
- Every machine has an IP address: PLC → can be accessed via IP.
- "If everything is connected, everything can be at risk."
- The security of IoT devices can be the weakest link.
📌 Conclusion: Security = Continuous Production + Human Safety
Industrial cybersecurity is not just the responsibility of IT, but the shared responsibility of the entire factory. Acting proactively is protecting not only against threats but also against the future.🗨️ Join the Discussion
- What measures are being taken for OT security in your company?
- What is the most common type of threat you encounter in the industry?
- Are cyber exercises conducted on SCADA systems?
🧠 Share, discuss, learn. Because the future of production is shaped by security.
💬 I await your questions, comments, or case studies below!
