Dunkermotoren Adds Functional Safety to Brushless DC Motors
Dunkermotoren's dSafe technology provides safety functions by integrating PROFIsafe and FSoE protocols into brushless DC motors. It safely performs operations such as safe torque off and limited speed.
Safe Servo Motor Solution from Dunkermotoren: Wireless Safety with dSafe
For years, servo motors have simplified automation systems by providing safe signals with Ethernet-based safety protocols. This shortens assembly and integration times.
As a recent development, the new dSafe safety technology, integrated into Dunkermotoren's BG75 and BG95 series brushless DC motors, has been introduced. This technology performs safety functions directly within the motors, reducing wiring and troubleshooting processes.
Safety Functions
Dunkermotoren’s dSafe will be directly integrated into the BG75 and BG95 brushless DC motors
Motor drivers provide power under PLC control; however, safety systems require additional measures to prevent operator inputs. Functions such as safe torque off (STO), safe limited speed (SLS), and safe stop (SS1) traditionally operate with wired safety outputs.
dSafe, on the other hand, manages safety functions directly through the motors using communication protocols like FSoE or PROFIsafe. This eliminates complex wiring issues and troubleshooting processes.
What is SLS?
In areas where operators work in close proximity, the SLS function automatically reduces motor speed. When an area scanner detects an operator, it reduces motor speed, increasing reaction time and ensuring safety.
What are SS1 and STO?
To safely stop the motor, either power is cut directly, or the motor is brought to a safe stop. Using a safety output, the motor is stopped in a controlled manner, and protective doors are opened. Without a safe stop function, the control system only releases the STO signal; this means an abrupt stop and risks safety.
Advanced Safety and Easy Integration
With dSafe technology, Dunkermotoren aims to eliminate complex wiring, thereby reducing production and commissioning times. Compatible with PROFIsafe and FSoE protocols, dSafe can be easily integrated into new and existing systems.
With dSafe, users can avoid complex wiring that a traditional setup would require
Dunkermotoren's safety-focused innovation enhances safety and efficiency in industrial automation.
Packaging machines with open concepts require advanced safety feature sto keep operators safe
