🔐 Sopcos - The Constitution of the Machine (Why do we need a new language for Industrial IoT?)
  • 🔴 CODE IS NOT LAW​
    SIP-001 and the Constitution of the Machine​
    Code:
    { "verdict": "DENY" }
    For years, in the world of automation, we've been doing the same thing:
    We tell the machine what to do.
    "Open the valve 50%."
    "Start the motor."
    "Stop if pressure exceeds X."
    But no one asks the question:
    "Is this action correct right now?"
    "Is it legal?"
    "Is it safe?"
    📌 This is where the fundamental problem begins:
    Code is not law.
    ⚙️ Automation Knows "HOW," Not "INTENT"​
    Traditional PLC and automation software focuses on:
    • Input / output
    • Condition / action
    • IF → THEN
    But it never asks the question:
    "If the pressure is already at a critical level,
    is it legitimate to open this valve?"
    Because the software:
    • Cannot judge its own actions
    • Cannot know if its decision is ethical, legal, and safe
    That's why we now need:
    A language that governs intent, not action.
    📜 What is SIP-001?​
    Not Code, but the Machine's Constitution​
    SIP-001 is not a script.
    It is certainly not a programming language.
    SIP-001 is this:
    It is the constitution of the machine.
    Meaning:
    • It does not say what to do
    • It decides whether what is desired to be done is legitimate
    📌 Important distinction:
    VERDICT, NOT COMMAND
    🧠 What Does SIP-001 Do?​
    When an action request comes in, it checks:
    • Does it violate the laws of physics?
    • Does it comply with occupational safety and regulations?
    • Does it infringe upon the hierarchy of authority?
    The outcome has only 3 possibilities:
    • ALLOW → Safe, proceed
    • DENY → Forbidden
    • WARN → Risky but permitted (with accountability)
    Sopcos is the judge, not the executioner.
    🚨 Default Safety = DENY​
    Fail-Closed Principle​
    In most systems:
    "If there's no rule, proceed."
    In SIP-001, the rule is clear:
    If there is no matching policy, the answer is always DENY.
    📌 If the constitution is silent, the machine stops.
    Because:
    Safety cannot be left to chance.
    🏛️ Decision Hierarchy (SIP-008)​
    Whose word carries weight in the system?
    Ring 0 – Physics
    Absolute authority. No one can override it.
    Ring 1 – Law & Occupational Safety
    Regulations, standards.
    Ring 2 – Human
    The operator can decide but takes responsibility.
    Ring 3 – Artificial Intelligence
    Only an advisor.
    ❌ Never gives commands.
    🔐 Override = Not Innocent​
    "Not Intervention, but Confession"​
    The operator can manually override the system.
    But in Sopcos, this is:
    A cryptographic confession.
    Meaning:
    "The decision is mine.
    If an accident occurs, the responsibility is also mine."
    This is not an overreach of authority, but a conscious declaration of responsibility.
    🧼 Dirty State (SIP-006)​
    Once an override is performed:
    • The system enters a Dirty State
    • Data generated during this process is not considered reliable
    To clean it:
    • The operator is not enough
    • An independent Auditor's digital signature is required
    📌 The system is not cleared without paying a price.
    🤖 Artificial Intelligence is Not an Authority​
    In the Sopcos architecture, AI:
    • Cannot make decisions
    • Cannot spend money
    • Cannot generate commands
    Even if it is 99% sure:
    If SIP-001 says "NO," the result is NO.
    ✔ Yes to autonomy
    ❌ No to irresponsible autonomy
    🔮 The Era of "I Didn't Know" is Over​
    Sopcos Simulation Engine (SIP-005):
    • Calculates the consequences of a rule change in advance
    If the system:
    Said "This will lead to an explosion"
    and it was still signed off...
    This is now:
    Not an accident, but deliberate negligence.
    🏭 Machines Now Have Identities​
    A boiler is not just metal.
    It is an Industrial Identity (IDAS).
    • Its history on the chain
    • Maintenance recorded
    • No fake parts
    • Every screw verifiable
    📌 Machines are no longer anonymous, but accountable.
    🔚 Conclusion: Autonomy Requires Accountability​
    We are not just making machines smarter.
    We are making decisions ownable.
    Code is not law.
    Law must be above code.
    💬 What do you think?
    • Is such a "constitution" possible beyond PLCs?
    • How many industrial accidents are truly "accidents"?
    • Is it right to give so much authority to artificial intelligence?
    I'm curious about your opinions.
    Source: Ekrem ORAL
    Sopcos Foundation
