Sanyo Denki Standby UPS with 200% Overload Capacity
Akademisyen
    ## Sanyo Denki Unveils Standby UPS with 200% Overload Capacity for Motorized Equipment
    Sanyo Denki has introduced the SANUPS N11D standby UPS model, which supports variable loads for motorized machinery and offers an overload capacity of up to 200%. This UPS ensures uninterrupted power by preventing power fluctuations encountered in elevators, robotic systems, and semiconductor equipment.
    The SANUPS N11D is specifically designed for voltage sags, sudden current surges, and short-term overload conditions frequently experienced in industrial environments. Despite its compact structure, it offers high overload tolerance and power conversion efficiency of up to 98.6%.
    ### Key Features of SANUPS N11D
    • 200% overload capacity (short-term)
    • Maximum 98.6% power conversion efficiency
    • Seamless power transfer time of 10 ms or less
    • Backup mode output voltage control of ±3%, frequency control of ±0.5%
    • Noise level: Approximately 30 dB at full load (quiet operation)
    • Three versions: Lead-acid battery, lithium-ion battery, and electric double-layer capacitor (EDLC)
    • Capacity options from 2 kVA to 3 kVA
    • In-panel, wall-mount, or floor-standing installation options
    • In lithium-ion and lead-acid models, battery and UPS can be separated for easy installation in narrow spaces
    The SANUPS N11D meets the sudden current surges during motor startup, minimizing interruptions and equipment loads in industrial processes. Operating in compliance with SEMI F47 voltage sag standards, the system provides stable power even for sensitive equipment.
    Energy saving and low heat generation are prioritized, and the device's Eco Product Plus certification reduces its environmental impact. Its quiet operation also makes it suitable for use in control rooms and near operators.
    ### Application Areas and Recommendations
    The SANUPS N11D is recommended for critical applications requiring uninterrupted power, such as commercial elevators, high-speed doors, industrial fans, cold storage facilities, semiconductor manufacturing machines, and robotic or motor-based automation systems. Even short power outages can lead to production loss, equipment wear, and raw material waste, making fast and overload-tolerant backup power solutions indispensable.
    The SANUPS N11D offers reliable and durable solutions for motorized industrial equipment for system designers and integrators. It overcomes the problems traditional UPS units face with inrush currents, guaranteeing continuity in modern industrial processes.
