## HMS Networks Strengthens Integration and Communication with New Gateway, Software Update, and MQTT Support
HMS Networks has announced the new NIBE Gateway for heat pumps, a significant software update for the Anybus Atlas2 Plus monitoring system, and the addition of MQTT communication protocol support to Intesis 700 Series Air gateways.
### Integration of Heat Pumps into Building Automation with NIBE Gateway
The new NIBE Gateway enables the integration of heat pumps into Building Automation Systems (BAS) in multi-residential buildings and small commercial areas. This gateway can establish bidirectional communication between 5 different heat pumps and 100 data points. This allows for easy coordination of heating and cooling processes in complex HVAC systems.
The system is not limited to HVAC but can also be used in many applications such as photovoltaic cells and pool temperature control.
### Software Update for Anybus Atlas2 Plus
The 2.3.0 software update released for the Anybus Atlas2 Plus monitoring system fixes some bugs from the previous version and, most importantly, adds the Topology Tree View feature. This allows users to create a visual and functional hierarchy of connections between devices.
This feature simplifies understanding inter-device interactions in complex systems, saving time during troubleshooting and design phases.
The new version also includes the Atlas Update Tool. This tool speeds up maintenance processes by enabling multiple Atlas devices to be updated simultaneously.
The update also includes new versions of the Atlas and Tool user manuals.
### MQTT Support for Intesis 700 Series Air
HMS Networks' popular Intesis 700 Series Air gateways now support the MQTT communication protocol. This enables HVAC systems to send and receive data via the cloud, allowing for remote control and troubleshooting over the internet.
This support eliminates the need for physical control of HVAC components, providing great convenience in remote management and maintenance processes.
### Conclusion
HMS Networks offers both new products and software updates for existing systems to meet integration and communication needs in heating, cooling, and building automation systems. While the NIBE Gateway can be used for new installations and upgrading existing systems, the software update released for Atlas2 Plus can be easily applied to existing devices.
### Technical Specifications
- NIBE Gateway; bidirectional communication between 5 heat pumps and 100 data points
- Anybus Atlas2 Plus firmware version 2.3.0
- Visualization of network structure with Topology Tree View
- Atlas Update Tool offering multi-device update capability
- MQTT support in Intesis 700 Series Air gateways
