NASA, preparing for a crewed flight around the Moon, continues the countdown for Artemis 2 despite the controversial heat shield of the Orion capsule.
NASA's crewed Artemis 2 lunar mission continues to stir debate in the scientific community due to a problem detected in the heat shield of the Orion spacecraft.
With the mission scheduled to begin in early February, taking four astronauts on a historic journey around the Moon, some experts are warning against crewed flight, while NASA argues that the risk is manageable.
HEAT SHIELD MELTED IN FIRST TEST
The problem concerns the Avcoat-coated heat shield of the Orion capsule, which protects astronauts from extreme heat during its return to Earth.
The same design was used in the uncrewed Artemis 1 test flight in 2022, where unexpected cracks and detachments were observed on the shield's surface upon return. This forced NASA to launch a comprehensive investigation.
ROUTE CHANGED, NOT SHIELD
NASA's conclusion was to adjust the mission's return trajectory rather than completely replace the shield. According to the agency, changes in the entry angle will reduce exposure to heat and ensure controlled ablation of the shield.
NASA also points out that changing the manufacturing process carries uncertainties, emphasizing that whichever option is chosen, it involves risk.
SPACE RESEARCHERS DIVIDED
However, criticism continues. Some former NASA astronauts and heat shield experts argue that the Avcoat material being less permeable in Artemis 2 could increase the risk of cracking.
Experts who state, "If the heat shield starts to shed in large pieces, it means the system is operating at its limit," believe the flight should be postponed.
MESSAGE OF CONFIDENCE FROM NASA
On NASA's side, a message of confidence prevails. Agency officials state that based on tests, simulations, and independent reviews, they believe the crew's safety will be ensured.
Astronaut Reid Wiseman, designated as the mission commander, also states that the root cause has been understood and that with the new return profile, the risk is at an acceptable level.
WHAT IS A HEAT SHIELD? WHY IS IT IMPORTANT?
The heat shield is considered one of Orion's most critical components. Upon returning from the Moon, the vehicle enters the atmosphere at more than 30 times the speed of sound, and its outer surface is exposed to very high temperatures.
Although cracking of the shield is considered possible in Artemis 2, NASA engineers argue that this will not pose a vital threat to the crew.
The final decision will be made after the last risk assessments and flight readiness reviews.
