Mandatory Periodic Inspection Control Reports (ISGUM - Ministry of Labor and Social Security)
  • Hello, You can download the Mandatory Periodic Inspection Control Reports, documents belonging to İSGÜM - Ministry of Labor and Social Security, from the attachment...
    Note: Mandatory periodic control reports must be used in the format in which they are published. Additional information regarding the formal use of the format in the reports: The main headings and their order should not be changed, but the sizes and placements of the contents can be modified.
    DescriptionEffective DateRev Date
    ZPKK01 - Low Voltage Earthing System Periodic Control Criteria1.09.202518.07.2025
    ZPKR01 - Low Voltage Earthing System Periodic Control Report1.09.202518.07.2025
    ZPKK02 - Electrical Internal Installation Visual Inspection and Function Tests Periodic Control Criteria1.09.202518.07.2025
    ZPKR02 - Electrical Internal Installation Visual Inspection and Function Tests Periodic Control Report1.09.202518.07.2025
    ZPKK05 - Transformer 1-36 Kv (HV) Visual Inspection and Earthing System Periodic Control Criteria1.09.202518.07.2025
    ZPKR05 - Transformer 1-36kv (HV) Visual Inspection and Earthing System Periodic Control Report1.09.202518.07.2025
    ZPKK04 - Fire Detection and Alarm Systems Periodic Control Criteria1.09.202518.07.2025
    ZPKR04 - Fire Detection and Alarm Systems Periodic Control Report1.09.202518.07.2025
    ZPKK03 - Lightning Protection System Periodic Control Criteria1.09.202518.07.2025
    ZPKR03 - Lightning Protection System Periodic Control Report1.09.202518.07.2025
    AA01 - Explanations Regarding LPG Tank Periodic Control18.07.202518.04.2025
    ZPMK01 - Liquefied Petroleum Gas (LPG) Tank Periodic Inspection Criteria18.07.202518.04.2025
    ZPMR01 - Liquefied Petroleum Gas (LPG) Tank Periodic Inspection Report18.07.202518.04.2025
    ZYDK01 - Liquefied Petroleum Gas (LPG) Tank Reassessment of Competence Criteria18.07.202518.04.2025
    ZYDR01 - Liquefied Petroleum Gas (LPG) Tank Reassessment of Competence Report18.07.202518.04.2025
    AA02 - 1st Norm Regarding Periodic Control Processes9.05.20259.04.2025
