Leuze FBPS 600i Safety Barcode Reader Connects to Safety PLCs with Integrated PROFIsafe | Safe Positioning with Performance Level e for Crane and Assembly Applications
Leuze Introduces: FBPS 600i Safety Barcode Scanner with Integrated PROFIsafe
Leuze is empowering industrial applications with its new FBPS 600i safety barcode and positioning system, which is PLe-rated in the safety class. Thanks to PROFIsafe interface support, this system connects to safety PLCs, providing precise position detection in cranes, grippers, and assembly lines.
Features and Advantages
The FBPS 600i safety barcode reader now includes the PROFIsafe interface for connecting to a safety PLC
Easy Installation
The FBPS 600i is specifically designed for stacker cranes commonly used in warehouse and industrial automation. Its single-screw mounting feature ensures quick and secure installation; the clamp bracket easily attaches to the crane or transfer carriage, and removal for maintenance is simple.
Bidirectional Communication
It supports linear topology with standard M12 ports and can be easily configured via an integrated web server. Settings can also be made via GSDML file through PLCs.
Long Distance and Reliability
Ideal for long-distance moving cranes, the FBPS 600i provides high-precision position monitoring when mounted on moving components. The tactical barcode reader scans multiple codes during movement, and the system determines the position with software support.
Industrial Automation and Fast Detection
In automated warehouse systems, the position of products placed on high shelves is detected safely and efficiently by the FBPS 600i. This allows loading and unloading operations of cranes to be performed without error.
Leuze's new safety barcode system offers a reliable and easy-to-use solution that meets industrial automation and safety needs. For detailed information, seek support from experts.
Leuze’s FBPS 600i safe bar code system relies on a one-screw fastening system that enables secure and accessible mounting
- Safety and Accurate Position Reporting: High-accuracy position reporting with customized barcode tapes.
- PROFIsafe Integration: Ability to communicate with safety PLCs.
- Versatile Connectivity: Can also be used with a non-safety SSI interface, providing the same precision.
- Durable Design: Prevents errors through inclined beam technology and tolerates damaged tapes.
- Operating Range: Between 50 mm and 170 mm.
Easy Installation
